you should have a post with your disk package from cand the post is touch and go there is a # you have to put in for your switch offset in the post open I think in word put in your #.50 or whatever it is and save this is for your machine now.
This is for if your machine has a floating head your plasma torch lowers and touches the metal triggers the switchso it knows where the metal top is raises to peirice height pierices lowers to cut hieght and starts your cut
you don't have to have your plasma on to see if it works you will get a fault in mach just trigger your manual plasma button off and the machine will start to move the gantry
LinkBack URL
About LinkBacks
