Results 1 to 8 of 8
Thread: need opinion on DTHC
    Oct 2011
    indonesia
    Hi guys which one is better for THC is it CandCNC DTHC (Digital Torch Height Control) or Mach3 (CAP04)? I'm not sure wether they are using the same sensing technology.
    Thank you in advance
    Jan 2011
    It looks to me like that CAP04 still needs a torch height controller to work, if I'm reading it right...it's just a switch, in essence. (maybe?)
    The CandCNC DTHC is what I use, it works very well.
    Carl
    May 2009
    I use the LCTHC from candcnc and it works great. I've got many hours of cutting with it and the results are perfect and very consistent. It doesn't have all the features of their upper end equipment but it costs a lot less and is more than sufficient for quality cuts. Talk to Tom at Candcnc and he'll give you all the pros and cons.
    Willy
    Jul 2005
    Quote Originally Posted by flyinwilly View Post
    Willy
    Here is a link to a comparison/features chart
    http://www.candcnc.com/DTHCCompareChart.htm
    One thing to note is the single cable connect to the Hyperthem 45/65/85 is only available on the DTHCII product.
    The MP3000-DTHC is a advanced BoB with Port Expansaion plus the RTHC.
    Oct 2011
    indonesia
    Thank you very much guys
    Oct 2011
    indonesia
    is MP3000E-DTHCII compatible with this plasma cutter? it's a weldteco 100amps plasma cutter
    Attached Thumbnails Attached Thumbnails need opinion on DTHC-13012012166%5B1%5D.jpg
    Oct 2010
    unknown
    If you can fire the torch on air, then MP3000 DTHCII is compatible with it, you just need to buy a DCP ( digital current probe ) and a RAV01 voltage sensor.
    Oct 2011
    indonesia
    Yes I can fire the torch on air.
    So all I need is MP3000E-DTHCII, dcp-01 and rav-01?
    1. anyone using everlast 60c w/ DTHC?
      By Momentz in forum Plasma, EDM and other similar machine Project Log
      Last Post: 02-18-2013, 03:12 PM
    2. $100 dthc
      By matttargett4 in forum General Waterjet
      Last Post: 03-14-2012, 10:47 AM
    3. Problem- DTHC
      By MAS in forum Plasma, EDM and other similar machine Project Log
      Last Post: 11-19-2011, 05:40 PM
    4. Need Help!- problem with DTHC MP3000
      By tessen in forum General Waterjet
      Last Post: 04-29-2010, 10:04 PM
    5. Need Help!- MP3000-DTHC-ESP.set
      By torraville in forum General Waterjet
      Last Post: 11-16-2009, 10:16 PM
