Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc
    Registered rexcobey's Avatar
    Sep 2010
    italy and Philippines
    This is my new build cnc plasma with USBCNC control by USB5-BEding CNC - PC based CNC control
    Attached Thumbnails Attached Thumbnails CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00272-20111120-1121.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00273-20111120-1121.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00274-20111120-1121.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00275-20111120-1122.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00276-20111120-1122.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00277-20111120-1122.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00278-20111120-1122.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00279-20111120-1123.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00280-20111120-1123.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00281-20111120-1126.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00282-20111120-1126.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00283-20111120-1127.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00284-20111120-1127.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00285-20111120-1127.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00288-20111122-2112.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00289-20111122-2112.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00290-20111122-2112.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00292-20111122-2113.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00293-20111122-2114.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00294-20111122-2114.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00295-20111122-2114.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00296-20111122-2114.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00297-20111122-2115.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00298-20111122-2115.jpg
    CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00299-20111122-2116.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-img00300-20111122-2116.jpg
    Sep 2010
    first cutting using oxy/acetylene
    http://www.youtube.com/watch?v=H_bwKFnCPc4&feature=g-upl&context=G27018a8AUAAAAAAAAAA]VID 00010-20111205-2200.3GP - YouTube
    Sep 2010
    i am using usbcnc CPU V5 by edingCNC
    http://www.youtube.com/watch?v=xAnijgQRgDw]VID 00012-20111205-2222.3GP - YouTube
    Mar 2004
    Wisconsin
    Rex,
    Will you find some time in the near future to give us all a solid viewpoint on the Eding Control ? It is one of the newer USB controls out there and very little forum discussion exists.
    Tell us about the setup,.. tell us if you found any new radical "features" that you have never seen before. Also tell us what other controls you have used in comparison.
    It would be a great help to many.
    Chris L
    Sep 2010
    if you are intended to use this for cnc router, cnc mill and cnc lathe it is a good
    PC-based CNC control systems. But if you want to use this as control for cnc plasma i will not recommend.
    Because in my experience i cannot find a suitable THC in the market that run in this control and his software. The only thing that you can use is Stand Alone THC ( i use the one made by AGELKOM from Turkey ) that's you cannot control in software not like in Mach3. But in all the aspect it is a great product and great technical Support. Also there is another guy in Netherlands (damencnc) has trying to do the THC for this cnc control and i am waiting for it.
    Sep 2010
    Update for my cnc plasma gantry
    a new update for my gantry i just add a spindle in my system
    Attached Thumbnails Attached Thumbnails CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-20120330_145524.jpg   CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc-20120330_150138.jpg
  7. #7
    Sep 2010
    update on my gantry
    http://www.youtube.com/watch?v=M5zNxsqYViE&context=C495dcc0ADvjVQa1PpcFMGiaEClvFZdYXW-zCtTC8QEGUiUS92dHQ=]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting parts 1 - YouTube
    http://www.youtube.com/watch?v=2EqUb6uJGDo&context=C4f18e6aADvjVQa1PpcFMGiaEClvFZddGljYDScGix3xQqlnmQpyc=]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting Part 2 - YouTube
  8. #8
    Registered Zygoat's Avatar
    Feb 2010
    how thick was that?
  9. #9
    Sep 2010
    Quote Originally Posted by Zygoat View Post
    how thick was that?
    That is 25mm thick mild steel plate
  10. #10
    Sep 2010
    New update on my gantry
    This my new teknomotor
    My gantry with water pan
    my teknomotor beside my oxygen fuel torch
  11. #11
    Sep 2010
    here is more
    Slave axis ( A axis slave by X axis )
    X axis
  12. #12
    Sep 2010
    more picture
  1. Replies: 0
    Last Post: 05-26-2011, 08:30 PM
  2. Replies: 0
    Last Post: 05-02-2011, 02:00 AM
  3. Replies: 0
    Last Post: 04-04-2011, 02:20 AM
  4. Replies: 0
    Last Post: 04-03-2011, 06:20 PM
  5. Gear Rack Sources-10ft.
    By utahnorton in forum Linear and Rotary Motion
    Last Post: 05-17-2006, 10:39 PM
