Results 1 to 10 of 10
Thread: agiecut classic s , pc connection
    Jun 2005
    israel
    we have recently bought used agiecut classic s , whats the procedure to connect it to the pc , for file transfers to the machine . it has a what looks like a parallel port connector.
    Oct 2010
    Probably a 25-pin serial connector.
    Jun 2005
    israel
    you are right it has a 25 pin serial connector at the machine , what cables to use ? , what software on the pc?
    Oct 2010
    A serial cable.
    I believe you'll just use something like hyperterminal to communicate.
    Nov 2011
    Hyper terminal
    I have a classic 3 with an off line cam software (PEPS) we tried transfer files with hyper terminal but have to transmit so many files for it to work. We found it was better to transmit using a floppy disk
    Oct 2010
    I dropped one of those 3.5" floppy replacements that takes the USB stick into my Agie 170. Works perfectly.
    Format a 256meg USB stick using the software included with the drive, and it makes 100 folders numbered 00 to 99. There is a 2-digit display on the drive that allows selection of each digit.
    Voila -- like having 100 floppy discs for fast access. Very easy.
    Nov 2011
    If you have a classic 3 it is running OS 2 and it does not support USB
    Oct 2010
    The drive I mention is a REPLACEMENT for the 3.5" floppy.
    If the machine contains a floppy disk drive, this drive I mention that has a USB plug will work.
    Dec 2011
    Belgium
    One off the best ways is to use the tcp/ip network conection
    You can map a network share to a drive letter
    Then you can use the inport / export funtions
    Feb 2012
    Philippines
    Quote Originally Posted by precisionmetal View Post
    precisionmetal
    Could you give me a link on where to buy this usb floppy emulator that will work
    on AGIE WEDM, need one also?
    TIA!
    1. agiecut hss 250
      By robert0707 in forum General Waterjet
      Last Post: 05-03-2012, 10:59 PM
    2. AGIECUT Classic S system error at startup
      By SINUMERIKO in forum General Waterjet
      Last Post: 11-10-2011, 07:25 AM
    3. Looking for agiecut 100 parts
      By jess fuqua in forum General Waterjet
      Last Post: 07-22-2011, 11:44 PM
    4. Replies: 0
      Last Post: 07-12-2011, 04:00 AM
    5. Wire EDM AgieCut 120, programming problem!
      By julioykaly in forum General EDM
      Last Post: 06-14-2011, 02:52 PM
