Results 1 to 2 of 2
Thread: Mitsubishi Waterjet trouble shooting
    Aug 2011
    We have a Mitsubishi Electric Suprema Waterjet system. We've had it almost a year and have had an ok time up till now. In the last week or so we have been having a bad problem with our tips clogging multiple times a day. We haven't changed the type of sand we use. its the same tips we've been using, and We actual had a brand new tip blow apart at it end yesterday while cutting.
    Has anyone else ever had these 2 issues , or maybe have an idea on what could be cause them?
    Thanks in advance for the help guys
    JoJo
    Mar 2012
    The Netherlands
    It may be a little late but this may come in handy for future problems: The most likely cause of focussing tubes clogging up is an inaccuracy in the height sensor or a slow response of the Z-axis. The tip touches the material when piercing, the abrasive can't go anywhere which in turn blocks the water flow. If the pressure builds up to quickly in the tube - especially if it hits the material hard - it will shatter.
    Try testing a greater piercing/cutting distance or recalibrate the height sensor.
    Goed luck!
    Houvast
  1. Trouble shooting
    By PlasmaCraft in forum General CNC Plasma And Oxy Fuel Cutting Machines
    Last Post: 08-16-2011, 03:18 AM
  2. NEED HELP WITH TROUBLE SHOOTING MANUALS
    By salvador781 in forum Bridgeport and Hardinge Mills
    Last Post: 02-06-2010, 10:43 PM
  3. Need Help!- Trouble shooting drive board
    By boxwood in forum General Electronics Discussion
    Last Post: 07-14-2008, 07:24 PM
  4. looking for help with UNIDEX 12 trouble shooting
    By mad application in forum Want To Buy...Need help!
    Last Post: 01-28-2008, 03:21 PM
  5. Trouble Shooting Help
    By Outlaw6700 in forum Milltronics
    Last Post: 08-20-2007, 10:22 PM
