Results 1 to 8 of 8
Thread: Waterjet cutting question
    Apr 2010
    West Michigan, USA
    New to waterjet. Trying to cut 1.25 mild steel. Started off fine, now it seems like it does not want to cut. Is it possible to get the mixing tube plugged and it still pass water?
    Registered WATERJET71's Avatar
    Apr 2011
    Quote Originally Posted by grttt3 View Post
    Hard to tell why is not cutting,no sand in the bulktank, your orifice is damage,your mixing tube is plugged.
    Aug 2005
    Well check your pressure, and if you have intensifier pump, count how many shifts per minute. The number of shifts tell what output flow level is. This helps to determine
    if the orifice is clogged. If orifice not clogged, but nozzle is, then very likely the water
    will shoot to the abrasive inlet. Also check the abraisive valve if there is one. Many
    reasons could be. Just provide more observation.
    Apr 2010
    West Michigan, USA
    Abrasive is on, about 52 shifts per minute.
    I took orifice out and it looks like it is getting worn?
    Attached Thumbnails Attached Thumbnails Waterjet cutting question-2011-08-17_11.52.01.jpg
    Aug 2005
    How long have you been working with this orifice? It looks quite
    unsual.
    Apr 2010
    West Michigan, USA
    Orfice is from a flow phaser 3. Machine was purchased from an auction, about 10 yrs old.
    Aug 2005
    so you don't know how long this orifice has been used ?? Ruby orifice is usually good for
    30-40 hours. And most of time it is the ruby gets broken and causing the jet defocused, and hence not able to cut.
    Apr 2010
    West Michigan, USA
    Did not know that. Thanks! I will try new orifice.
    1. Is there any guy operating waterjet cutting?
      By livemott in forum General Waterjet
      Last Post: 08-01-2011, 09:57 PM
    2. Newbie- New to waterjet cutting
      By Gerdy in forum General Waterjet
      Last Post: 01-09-2011, 11:50 AM
    3. New Machine Build- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
      By kelvinguo in forum Want To Buy...Need help!
      Last Post: 09-19-2010, 09:40 AM
    4. New Machine Build- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
      By kelvinguo in forum General Waterjet
      Last Post: 09-17-2010, 04:09 AM
    5. Just IN- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
      By kelvinguo in forum Product and Manufacturer Announcements
      Last Post: 09-17-2010, 03:51 AM
