Air Plasma, when cutting at the speed that produces minimal dross...has about a 5 to 15 degree lag angle in the arc.....meaning the bottom of the arc trails behind the top. On most cnc machines (I don't know what you are using) there is a function that holds the plasma arc on after the machine motion stops at the end of the cut....it is a timed function that should be set differently for different materials and thicknesses. On some machines it is called "plasma off delay".
Another way to solve this "drop cut" issue is to program a lead out at the end of the cut....so that the part program crosses the starting curve and drives past the end of the cut about .150" or so. Another way to minimize the issue is to simply slow the process down a bit...however this often produces a bit more dross (called low speed dross.)
jim Colt Hypertherm
LinkBack URL
About LinkBacks
I'll do some more experimenting and see if I can find a solution!
