Does it do the same thing with the THC off during the cut? Easy way to tell if your THC is causing anything...
I sometimes see similar squiggles on two opposing sides of squares, if I have a high cut speed. I attribute it to flex in the gantry...when it changes direction, the torch vibrates a little bit, which translates to wiggles in the cut. It goes away if I slow down the cut.
LinkBack URL
About LinkBacks
Good call! I remembered that the z axis crashed into a box i had on the table when it took off looking for a home switch on the x axis. The problems all started after that. I tore down my z axis and found that the linear rail bearing block has 3 bearings that ride against a steel rail on each side. A 3rd bearing is in the middle and can be moved left or right to take up the backlash via set screws and then locked in place. I also noticed one of the fixed bearings was .015 out of plane. This allowed .015 backlash on the x axis and .023 on the y axis. more than enough to cause problems with the 6 inches of travel on the z axis.
