maybe somone just moved manuely by accedent
hi,could anyone tell me how the UV alignment could move nearly 2.5mm in U and 0.6 in V from it was last set to vertical
hi,i probably didnt explain it to well,when we set the wire to vertical we noted down the UV coordinates and now they have changed by nearly 2.5mm and 0.6 i hope this explains it better
By the sounds of it, someone must have had a crash. What model Agie?
hi,its a Agie 150 hss,could there be another explanation for this,as we let another bloke use this machine and he has said that he does not know how it has happened,and would there be some visible damage if a crash had happened?
A couple of things: Was he cutting a taper and stopped the cut? Maybe he re-started a job and stopped it while it was moving to initial position on a taper cut? Another thing, is the wire out of square that much or is it just the values aren't at zero?If the wire is out of square that much, then most likely it was crashed, usually the flush nozzles get smashed up pretty good. If none of these occurred, then you can bring it back to zero manually by using the handbox and homing U and V
Sounds like a head crash to me to,you say that another guy uses it and he doesn't know how it happened, doesn't sounds right does it,does he know how to use the machine properly?might be better off not letting him use it in future
