Results 1 to 5 of 5
Thread: Is This A Good Swap
    Oct 2008
    Is This A Good Swap
    I have a chance to swap my Thermal Dynamics PackMaster 50 for a ESAB PCM-1000i machine. The ESAB is a much bigger machine, but does not have a machine connection port like the TD PackMaster does.
    I plan to build a CNC table and use the plasma tourch on that table. I plan to cut 3/8in max plate thickness which could be done by either machine. Both have 25ft torches. I have a machine head for the TD machine.
    Is there any problems with using a plasma torch that doesn't have corner slow down on a CNC table?
    The TD system has the corner slow down capability, but I don't know if it's required.
    Any feedback to help with this trade decision would be appriciated.
    RUN-A-MUCK One Man's Junk Could Just Be Junk
    Jan 2008
    Both are high frequency start machines.....be sure that your cnc machine build takes this into account as it will require some special design in regards to grounding, shielding cables, and filtering and optically isolating inputs and outputs.
    You should be able to interface the torch start wiring right where the Esab torch connects inside the power supply.
    The "corner slowdown" that is on the old Packmaster 50 is not necessary with todays cnc machines that have better corner acceleration and de acceleration as compared to some older technology machines.
    It is probably a fair trade, although you may be better off holding out for a non high frequency start plasma....which will make your cnc build much easier and less costly.
    Jim Colt
    Oct 2008
    Quote Originally Posted by jimcolt View Post
    Jim Colt
    Jim,
    How do the new plasma torches start up if they don't use high freq to start the pilot arc?
    Jan 2008
    The newer technology air plasma systems use the "blowback start technology as described below. This is a canned explanation that I use...as this question come up often. It describes the differnces between high frequency start, pilot arc, and non high frequency start technologies in plasma torches.
    Jim Colt
    There are two popular ways to ionize the gas in a torch...."High Frequency", high voltage discharge, and the "Contact start" or blowback start method.
    High frequency starting uses a high voltage (around 15,000 volts) high frequency AC electrical source to create a high intensity spark inside the torch to heat the plasma gas. This discharge, similar to the power used to fire spark plugs in an internal combustion engine, is developed using circuitry in the plasma power supply, and is transmitted through wires in the torch leads to the torch. High frequency plasma systems (as well as tig welders with high frequency) have been known to cause issues with sensitive electronic devices. Many cnc machines that use a standard PC as their controller often have issues with electrical noise interference that is caused by this starting method. Industrial CNC machines often are designed with complex grounding and filtering that allows high frequency plasma systems to be used without issues.
    1.Some high frequency torches are designed to fire a "pilot arc" which is a high intensity arc that essentially will fire in the air. These types of torches work well with transferring the arc to rusty or painted surfaces. Once the pilot arc makes electrical contact to the plate being cut..the main plasma power ramps up and the cutting process begins.
    Many older technology air plasma systems uses this high frequency/pilot arc starting method. All high end industrial plasma systems currently use this method of starting....as it allows for better torch accuracy (cut quality) and starting reliability in high duty cycle applications.
    2.Other high frequency torch designs (generally very low cost copies of old plasma technology) use high frequency to create the arc through making physical contact with the plate. These torches, often know as high frequency start or scratch start must actually have the nozzle in extremely close proximity to the plate, or on dirty, rust plate must scratch through the surface of the plate in order to allow the high frequency discharge to make contact and ionize the gas.
    This technology is generally reserved to very low cost hand plasma cutting systems. It is difficult at times to get the arc to transfer to the plate, and is not generally good for mechanized cutting applications as the nozzle must be in very close proximity to the plate in order to transfer tha arc....which causes molten metal to blow back and damage the nozzle orifice.
    3.The contact start or blowback start torches (developed by Hypertherm, but used by many companies today) use a moving electrode inside the torch. The main DC power is activated in the plasma torch, then moments later the gas flow starts in the torch. The gas flow causes the spring loaded electrode to slide back away from the nozzle, which creates a short circuit spark that ionizes the gas flow through the torch. These torches will fire in the air, and will penetrate through rusty, dirty, painted surfaces as well as the first method of High frequency with a pilot arc.
    The majority of air plasma systems use this technique today for hand and mechanized cutting applications. This innovation allowed for smaller inverter based plasma technology systems to become easier to use, and lower priced. Since there is no high frequency discharge, these types of systems can be used on many entry level cnc machines with no need for additional grounding and filtering, and since there is a pilot arc, they can transfer to the plate from a distance...allowing for piercing on thick plate with no nozzle damage.
    Oct 2008
    Jim Colt
    Thanks Jim That was a great discription of how the machines differ with respect to the pilot arc start.
    1. TNC-145 - 150 control swap?
      By jkruger in forum Bridgeport and Hardinge Mills
      Last Post: 02-23-2009, 04:17 PM
    2. Motor swap
      By QSIMDO in forum Industrial Hobbies (Support forum)
      Last Post: 01-07-2008, 09:33 PM
    3. Spindle motor swap, or servo swap?
      By Chuck Reamer in forum Tormach Personal CNC Mill
      Last Post: 10-09-2007, 01:54 AM
    4. Drawing swap
      By DLMACHINE in forum Rhino 3D
      Last Post: 12-19-2003, 08:30 PM
