Results 1 to 4 of 4
Thread: Best timing belt material
    Dec 2009
    I need to replace some long 1/2" wide L series belting that drives the long axis on my plasma table. I'm finding it in Urethane with steel cords which I have now, Urethane with Kevlar cords or Neoprene with fiberglass cords.
    I'm mainly concerned with it not stretching. Does anybody have the low down on which would be best for this application? I need it fast and can get the Kevlar locally on Monday but don't want to sacrifice performance.
    Thanks for any input.
    www.modernironworks.com
    Feb 2008
    I have experienced bad things with the kevlar corded timing belts. Stretching and eventually breaking. I would go back to the steel cord.
    This is just one machine's experience with kevlar, others may find it good.
    Scott
    May 2009
    I used nylon covered, fiberglass reinforced neoprene belts on my table and haven't had any problem with them at all. I expected the X axis belts to stretch quite a bit but I've only adjusted them once in 3 months and it was very minor. My belts are 3/4" with a .375 pitch. Got them from Econobelt for a really good price.
    Willy
    Dec 2003
    Check out Breco belts, they make for this application.
  1. Timing belt material
    By Bigrhamr in forum Linear and Rotary Motion
    Last Post: 03-12-2011, 11:44 PM
  2. HTD Timing belt and backlash
    By BWay in forum Linear and Rotary Motion
    Last Post: 12-20-2010, 01:17 PM
  3. Timing belt reduction, which to use?
    By phantomcow2 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-30-2005, 12:19 AM
  4. Timing belt capacity
    By ozzie34231 in forum General Metalwork Discussion
    Last Post: 10-21-2005, 01:36 PM
  5. timing belt reduction
    By drwc in forum Benchtop Machines
    Last Post: 05-23-2005, 04:31 PM
