Results 1 to 3 of 3
Thread: Lincoln Pro-Cut 25??
    Banned by Moderators
    May 2009
    I have a Lincoln Pro-Cut 25 Plasma Cutter and I was wondering if it would be sufficient enough for a 4' X 4' Table? I will mostly be cutting 1/8 inch thick material. Please forgive me if this is a stupid question... Plasma cutting is all new to me. Thanks. :-]
    Jan 2008
    The Lincoln ProCut25 will certainly work on a cnc machine, just remember it only has a maximum of 25 amps output at 35% duty cycle.....so it would be possible to exceed the duty cycle very quickly. I also recommend that you operate the system on 230 volt input power....as it draws 38 Amps on a 120 volt input line when operating at full output power...you would need a special circuit to operate on 120 volts input power.
    Jim Colt
    May 2009
    Thanks Jim. :-]
  1. Sa 200 Lincoln Wedler
    By DJB282000 in forum Welding, Brazing, Soldering, Sealing
    Last Post: 12-31-2011, 03:48 PM
  2. Lincoln or Hypertherm ?
    By Ubatoid in forum Plasma, EDM and other similar machine Project Log
    Last Post: 12-25-2010, 12:01 PM
  3. Need Help!- Lincoln SA 200
    By maddenfarms in forum Want To Buy...Need help!
    Last Post: 02-06-2010, 03:01 PM
  4. Hi All From Lincoln UK
    By Finlay in forum Europe Club House
    Last Post: 07-02-2008, 08:55 AM
  5. Need help with new welder : Lincoln TIG 300
    By delangecycles in forum Welding, Brazing, Soldering, Sealing
    Last Post: 04-07-2006, 10:43 AM
