Results 1 to 8 of 8
Thread: Fanuc W0 EDW
    Jan 2011
    uk
    Fanuc W0 EDW
    Hi, I'm new here. Seems a great forum, loads of different sections for help !
    Perhaps someone can help me? We,ve just had a Fanuc W0 non submerged wire machine.
    We're having problems with the feedrate. We can't slow it down for the approach. Our test piece is 32mm thick. The feed comes in at 1.9 mm per min and that's with the override set at it's lowest.
    Which of the settings controls speed ?
    Any help will be of value,
    Thanks Keith.
    Aug 2008
    united sates
    Increase servo voltage if set high enough it will stop feeding........!
    Jan 2011
    uk
    Quote Originally Posted by gabedrummin View Post
    That does the trick ! Thanks.
    Also, there is some type of micro switch that's actuated by the splash guard, this wasn't working, when we fixed it, it seemed to make a difference to controlling the speed.
    As we often work on long sections, we often need to remove the splash guard, is it OK to short it out. I don't see any need for this switch ( but then I'm a Japax 3B guy ) !!
    Thanks Keith.
    Aug 2008
    united sates
    Yea its okay but water gets all over...I would pull the switch interlock off the splash guard and put it in the switch , that way the machine will work with or with out the splash guard........
    Jan 2011
    uk
    Great tips, thanks !
    Here's a puzzler - on a part we did yesterday, a particular radius wouldn't graph - we got error code 20. We used I and J values for the rad. When programmed with R ( R 3.00 ) it graphed OK but when machined it crashed at this rad.
    I programmed the shape from the other direction and it cut OK using I and J values.
    I checked the intersections in Autocad and they were only .0004 mm out.
    The book says that within 20 microns it should be OK.
    Any ideas ?
    Thanks Keith.
    Sep 2008
    England
    Hi Keith,
    I also have a W0.
    For the feed as you have been (G95) servo feed but you can control with constant feed G94 F120. F being the feed rate of 1.2mm/min.
    F0.6 would be 0.6mm/min.
    Over ride can also be used with this by the switch on the panel front.
    You dont need to asign G95 unless previously using constant feed within a program.
    Hope this helps.
    Chris.
    Jan 2011
    uk
    I'll try that, thanks, Keith.
    Sep 2008
    England
    Keith,
    Error 20 is overtolerance of rad in G02-G03.
    distance between start point and ctr of arc and arc to end point exceeded value in Parameter 876.
    Chris.
    1. GE Fanuc & FANUC proprietary posts
      By CNCadmin in forum Fanuc
      Last Post: 03-20-2013, 10:54 AM
    2. FANUC & GE FANUC Repairs
      By RRL in forum Product and Manufacturer Announcements
      Last Post: 04-17-2011, 12:50 PM
    3. Replies: 5
      Last Post: 03-09-2011, 10:11 AM
    4. Fanuc & GE Fanuc Repairs
      Last Post: 10-01-2008, 01:42 PM
