Results 1 to 4 of 4
Thread: 0.7mm Bulletproof Material
    Registered Donie's Avatar
    Mar 2010
    Ireland
    Anyone know if 0.7mm bulletproof material can be cut by plasma, waterjet or
    Laser. Its a bit vague i know , Will know after lunch more info on material itself
    Donie
    Jan 2008
    It is likely thicker than .7mm.....probabbly more like 7 to 13 mm thickness. Normally either AR400 or AR500 series plate is used (often used for rifle range targets and for armor plating). These materials cut almost exactly the same as regular A-36 steel plate...when cut with plasma. Water jet will do ok, laser has a hard time with most of this type of plate.
    Jim Colt
    Jan 2006
    You are assuming he is talking about steel plate. He could be talking about polycarbonate (some people call it bulletproof plastic), kevlar, dyneema, spectra, any number of ceramic armor materials. At .7mm I would guess he is talking about some ballistic grade textile but we will obviously need more info to be sure. What the material is will dictate the best process to use.
    Matt
    Feb 2008
    Ireland
    What size rounds do you need to stop Donie, I often make the steel targets Jim is talking about. Some for high powered rifles but 12mm AR450 is required.
    It can't be a textile material you are asking about because 1. A plasma worn't cut it and 2. a scissors will.
    A .220 swift round will go through 15mm mild steel at 50yrds, it bearly marks AR450.
    Where are you BTW
  1. what material??
    By pauluk in forum Metallurgy
    Last Post: 05-19-2010, 06:35 PM
  2. What material is this ?
    By twocik in forum General Metal Working Machines
    Last Post: 07-29-2009, 07:51 PM
  3. Cut arched bulletproof glass with waterjet?
    By douglasco in forum General Waterjet
    Last Post: 05-07-2007, 05:52 PM
  4. Material???
    By Grass-hopper in forum JGRO Router Table Design
    Last Post: 01-25-2007, 07:21 PM
  5. Material
    By ryanduc in forum General Material Machining Solutions
    Last Post: 01-29-2005, 07:50 PM
