Results 1 to 3 of 3
Thread: agiecut hss 250
    Sep 2008
    Poland
    agiecut hss 250
    Hi
    I just bought a wire edm from agie. put it all back together and when starting erosion always get alarm "erosion start with wire in short circuit"
    I took apart both lower and upper arm assembly, clean it and put back together. It didnt help! Sometimes I also get alarms regarding generator 1 and 8, but I think generators are ok as I swapped both 1 and 8 with other ones and still got the alarms sometimes.
    any clues where to search or what to check??
    Jan 2012
    Iran
    Are you sure you have assembled generator output (FS+ and FS-) cables and gap voltage sensor cables (UFS+ and UFS-) in correct polarity?
    Sometimes disconnecting of gap voltage sensor cables cause short circuit error on display.
    May 2012
    I'm selling an Agiecut 250 HSS, When i sell it im going to provide a video of disassembling to help the buy in reassembling. When i do i can send you the video to see if it helps.
    If anybody wants to buy the machine is in Canada and i'm selling it for $15,000 CAN.
  1. AGIECUT Classic S system error at startup
    By SINUMERIKO in forum General Waterjet
    Last Post: 11-10-2011, 07:25 AM
