Results 1 to 4 of 4
Thread: Capturing that last bit of plasma smoke from water table?
    Jan 2005
    I was wondering if anyone had come up with a good design for capturing that last bit of smoke from a water table. I run my water right up to the bottom of the plate and I recently put a vac hose on my gantry so it sits right over the plasma cutter (hand torch). I'm having some good results overall but I was wondering if anyone had a come up with a really design for collecting the smoke around the cutter head.
    Dec 2005
    canada
    I have my table enclosed with clear plastic with a mezzanine over it I have a furnace fan on top the mezz sucking from the table and vents outside works verry well and is controled from the table to turn it on/off
    Jan 2005
    That a good suggestion. I recall seeing a set up like that once. How do you handle material loading? What type of plastic material did you make it out of? Do you have problems watching the cut through the material and dealing with tip ups?
    Dec 2005
    canada
    rite now i load by tactor or from the back of the truck
    I just use poly vapor barrier that you use on the house you can still see throught it
  1. New plasma table with water bed questions ...
    By zeoncomp in forum General Waterjet
    Last Post: 08-17-2011, 03:07 PM
  2. 4x8 plasma table with bladder style water tray
    By dhelfter in forum EBAY ADS
    Last Post: 06-15-2010, 10:10 AM
  3. New Machine Build- plasma table with mobile water bed
    By cristian gabor in forum Plasma, EDM and other similar machine Project Log
    Last Post: 02-07-2010, 02:26 AM
  4. Plasma Cutter Water Table?
    By Bobbyr70 in forum General Waterjet
    Last Post: 12-25-2007, 08:21 PM
  5. Plasma+water table on casters?
    By DeviousMW in forum General Waterjet
    Last Post: 05-05-2007, 12:51 AM
