you can take the G00G54G92 line out of the code. I tell people if you establish the part location before you hit run there is no need for the machine to reset it. That G92 in the program goes back to when machines wasnt able to store locations long term. If you have several G92 in the program you can go to EDIT and at the bottom of the screen hit Replace and in the top box type in G92 and in the lower box type G00 and hit replace all. That will take care of the problem if you are only programming with one coordinate.
LinkBack URL
About LinkBacks
