Results 1 to 3 of 3
Thread: Charmilles Robofil 290P Axis problem
    Registered BLACKMODE's Avatar
    Dec 2010
    Istanbul
    Arrow Charmilles Robofil 290P Axis problem
    Hi everyone
    Foreign slice is not good
    Try to explain my problem.
    I have Robofil 290P
    When the error limits movement,
    How can I set limits for the axis parameters?
    What are the procedures I need to do?
    I do not want to reduce the limit
    Previously resolved by turning the motor pulley,I want to set parameters
    Thank you in advance for your help.
    May 2009
    Singapore
    Robofil-290P
    The axis movement can be set by EXE-service-axis parameter settings.
    But why do you like to limit the movement? The error may be due to dried grease in the slides, rusty slides. Have you tried to clean the slides using wd-40 throughly and apply very light grease before starting?
    When you turn the motor pulley, is the movement is smooth?
    I believe you are getting movement fault. the main reason is some jerk in the movement.
    Please update how you fix the issue.
    Titan - Singapore
    Titan Engineering, Singapore. Titanium Metal & Alloy suppliers.
    Nov 2012
    Romania
    Does anyone know Robofil Service for 290p in Romania?
  1. Charmilles Robofil 200 startup
    By Shawn Lucas in forum General EDM
    Last Post: 12-08-2012, 03:34 AM
  2. Charmilles Robofil Wire Edm
    By sundara in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 10-13-2012, 09:26 AM
  3. Charmilles Robofil 200 programs
    By Shawn Lucas in forum General Waterjet
    Last Post: 04-02-2012, 05:07 AM
  4. Charmilles Robofil 4000
    By John Murphy in forum General Waterjet
    Last Post: 09-21-2010, 07:11 AM
  5. Charmilles Robofil 510 Aux codes
    By tallenttoolroom in forum General Waterjet
    Last Post: 09-13-2010, 06:25 PM
