It seems to me that you have a bad encoder.
Corrosion builds up over time on the encoder reference mirror and this seems to be the problem in this case. If you have a mechanic you could try switching the encoder from another axis. If the error indicated after the switch moves to the axis of the encoders' origin, you have a bad encoder.
LinkBack URL
About LinkBacks
