Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Robofil 310 (console 2)
    Aug 2010
    Portugal
    I´ve been working for a couple of months with a Robofil 310. I´m getting some measurements problem, because for example, imagine i´m opening a box 20*20... On top i get 20*20 , but it´s not constant... i get - 0.02 / -0,03 mesuring at the bottom. What do you recomend ? a 4 axis program to compensate that error ?
    Registered mdynac's Avatar
    Jan 2006
    try running a "guide set-up" in the measures screen.
    you must have the centering eye properly mounted.
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Aug 2010
    Portugal
    Quote Originally Posted by mdynac View Post
    I think that i might not have explained myself has i should. This is the problem: i have a simple geometry to do , like a 20*20 square , for let´s say 70mm height. On top i have a correct measuring , but below , the square is tight , for about 0.03... the problem is not on the wire alignememt. On a small height i don´t have any problem. Can it be because of low water below ?
    Dec 2006
    try and increase your wire speed and see if the bottom tolerance changes. It sounds like your wire is running slow so the diameter is changing more in the cut. If i am cutting a tall part i tend to program with taper but only use a few seconds to a minute of taper angle.
    Aug 2010
    Portugal
    Quote Originally Posted by sodickappsguy View Post
    yeah , i´d already been thinking about that and i´ll guess i have to do it. tks
    Feb 2009
    UK
    It could be an alignment issue. A taller part would increase the inaccuracy. Also, is that a direct cut or a rough and finish?
    Aug 2010
    Portugal
    Yes... E2 + E7 + E7
    Feb 2009
    UK
    What wire are you using and what application have you set in the technology? Is it steel you are cutting? Also, have you calibrated the wire tension recently?
    Aug 2010
    Portugal
    Yup , tension is ok... Im using LS25 , with TEC : LS25A , cutting steel. Doesn´t your geometry get larger where it gets more water ?? 0,02 , 0.03 ???
    Feb 2009
    UK
    Not if I rough and finish it doesn't. I'm not sure what that wire is. Is it a hard brass wire? If I wire through parts that thick with no draft I change the application to Stamping tool, mould part and use fully hard wire. I'm using a fanuc control though so technology setting is different. Sounds like you have Charmilles control.
    Have you tried calibrating your flushing if you think that might be affecting it?
    Aug 2010
    Portugal
    The wire is not copper , i dont know how to say it in English... Laton , maybe... it has 500 nws. I´m working ok , and this differences are only when i have from 40 mm or above (height)
    Feb 2009
    UK
    It's probably a brass wire you are using. Unless its a zinc coated wire? 500N/M is half hard. Try using a fully hard wire (900N/M) for wiring tall pieces with the correct technology settings. That should stop you getting these run outs
  • Page 1 of 3 123 LastLast
    1. Hoss Mill Console Project
      By hoss2006 in forum Benchtop Machines
      Last Post: 09-11-2010, 04:45 AM
    2. Looking for a used Hypertherm Manual Gas Console
      By RepL in forum General Waterjet
      Last Post: 06-26-2009, 01:52 PM
    3. Portable Console
      By Rodm1954 in forum Benchtop Machines
      Last Post: 07-17-2008, 02:52 PM
    4. Show us your Console or Pendant!
      By JerryFlyGuy in forum General Electronics Discussion
      Last Post: 01-14-2008, 01:06 PM
    5. Mach3 console?
      By RLC in forum Mach Software (ArtSoft software)
      Last Post: 10-18-2006, 02:50 PM
