Results 1 to 3 of 3
Thread: flow jet
    Oct 2007
    flow jet
    Does anyone know flow jet machines?
    I’ve been told (not reliably) that flow jet's machines can not be hooked up to a network. what I would like to do is hook the to machines i have to my shop network and access cut files from my server to have one copy of a file that can be loaded to each machine as to not have more than one version of that file scattered on multiple machines
    Feb 2008
    If your Fow Jet has the PC based controller (which most do), and it has a LAN Port (Cat4 or 5) as on our 5year+ machine, then you can hook it up to a network.
    May 2009
    canada
    The PC based FLOW machines can be hooked up to a network with no problems. The older FLOW machines with a LYNX control can not be hooked directly to a network, this being said you can use rs 232 to download the same G code file that is stored on a network to multiple machines. We do this now in our shop. One computer on the network that has a rs232 data transfer switch hooked to it which allows you to select which machine is connected to the the rs232 port. You transfer the file to the lynx controler from the network via the computer.
  1. using a air flow fixture
    By sizmo in forum Toolgrinding & Toolgrinding Machines
    Last Post: 07-28-2010, 05:47 PM
  2. Need Help!- Flow Waterjet
    By MarineMachinist in forum General Waterjet
    Last Post: 05-26-2010, 12:10 PM
  3. Newbie- Getting two 3d surfaces to flow together better?
    By Fleck in forum Rhino 3D
    Last Post: 12-17-2009, 12:28 PM
  4. Need Help!- X DAC Under Flow
    By sidstover in forum Bridgeport and Hardinge Mills
    Last Post: 11-11-2008, 09:01 PM
  5. Flow
    By Haeusser in forum General Waterjet
    Last Post: 03-13-2008, 09:04 AM
