Results 1 to 10 of 10
Thread: Needs help !!! Sodick A320D with AWT - Control EX21
    Dec 2009
    INDIA
    We recently purchased a preowned 1996 Sodick A320D with EX21 Control, M/c with single floppy drive ( Epson 486 SE PC ) m/c in excellent condition with very low EDHours , M/c installed properly , test cuts taken OK.
    Next week , while shuting down the m/c , operater made a mistake by switching "Source off" first , Next day on powering up the m/c , while booting m/c (SYSTEM LOADING stops at 11 ) displayed error " SYS2 Version up Install , insert floppy disk, press any key " , after that every time on booting, m/c displays same error and asks for system disc. I think this is abnormal.
    Pls. suggest.
    Atul M.
    mescotc@sancharnet.in
    +91 9823220324
    Dec 2009
    INDIA
    I forgot to mention, on loading SYSTEM DISC 2.1 & 2.2 m/c starts ok,
    We have Version 3.00JPY SOFTWARE for EX21
    Atul M.
    Dec 2009
    INDIA
    Hey , No one yet on the forum aware about this problem ? Needs urgent help
    Dec 2008
    india
    a320d
    your batteries om cpu-386 / cpu-86 are down. please change them. 980 Rs. /battery. ER-6 type.
    Dec 2009
    INDIA
    Thanks for the reply, but my problem had been already sorted out.
    Atul
    Dec 2009
    INDIA
    On my A320d EX21 control, has a UPS fitted inside control cabinet , DENSEI make, But UPS doesn't functions. power to cotroller goes off , when power supply goes off.
    pls.Suggest ,
    Is it required to replace UPS , OR replace, batteries , is it required to buy UPS/batteries from Sodick ?
    Dec 2008
    india
    Thumbs up ups batteries
    no need , buy from the market, 12V/5AH x 5 batteries.
    total 5 batteries u need to replace.
    Dec 2009
    INDIA
    Question
    REPLACED OLD BATTERIES WITH NEW ONES, 12V 4.5mA/h x 6 nos ,
    1st day OK , run m/c for 6-8 hrs , but when i switch off the m/c the UPS was still working on battery mode & power to control was ON , So I switched off the UPS by opening RHS door.
    2nd Day , after powering up the m/c , when I turned on ups, within few minutes UPS shows Overload, And gives ALARM , alarm doesn't go even when i switch off the Inverter switch , UPS is in Charging Mode , but alarm is ON
    Pls. Suggest.
    Mar 2007
    Exclamation Densei UPS MUE1051-FL
    We have replaced batteries in the above UPS. Upon power up, we get an alarm light w/buzzer - charger light - and battery indicators are lit. We have no manuals on the UPS.
    Does anyone know where to get an operators' manual?
    Has anyone experienced this and what does it mean?
    Regards.
    Sep 2007
    INDIA
    How much machines do you have SODICK A320D
    1. SODICK A530D EX21 4-AXIS
      By systronic in forum General Waterjet
      Last Post: 05-27-2010, 09:40 AM
    2. Sodick A320D help with flushing
      By XYZ machine in forum General Waterjet
      Last Post: 02-18-2009, 09:53 PM
    3. wiring schematics for Sodick A320D
      Last Post: 01-10-2009, 12:23 AM
    4. Need Help!- UG NX4 PostProcessor for Sodick EX21 A320D
      By Chris 1st in forum UG NX
      Last Post: 01-06-2009, 07:22 AM
    5. RS232 connection of Sodick A320D AWT EX21
      By Mouldmaker in forum General CAM Discussion
      Last Post: 10-20-2003, 07:36 AM
