Results 1 to 7 of 7
Thread: anyone know about usingram/wire EDM for
    Aug 2007
    ...internal helical splines. Is it possible for Wire EDM and is there a proper graphite electrode to use for Ram EDM??? If you have pictures of how an internal helical spline can be made in a hole by Wire or Ram EDM that would also be helpful.
    http://www.frenco.de/multimedia/Grup...al_page-67.jpg
    http://www.rushgears.com/images/customHelicalAD.gif
    I know that these pictures are of external helical splines/gearsbut i would like to know if an internal helical spline can be manufactured using Wire/Ram EDM???
    Feb 2009
    UK
    We ram EDM'd this.
    I made the electrode on a Mikron CNC and sparked it on a Charmilles roboform. Was actually very easy. Hardest part was making the 3D geometry as it came in as a 2D drawing
    Attached Thumbnails Attached Thumbnails anyone know about usingram/wire EDM for-helix.jpg
    Aug 2007
    Thanks for your response and picture!!! That is very impressive. Do you have a picture of the electrode???
    Aug 2007
    Feb 2009
    UK
    The electrode was machined on both sides on a 3r pallet and then transfered onto the fixture.
    Just so you know, the cylindrical shape was all machined in, you could wire edm that form if it was critical. The electrode just sparked out the gear form.
    Attached Thumbnails Attached Thumbnails anyone know about usingram/wire EDM for-helix_electrode1.jpg   anyone know about usingram/wire EDM for-helix_electrode2.jpg
    Aug 2007
    Thanks again for your response. Could this electrode be used in a circular closed hole as opposed to your half a hole???
    And what material is that electrode made of and can the shape of the electrode be machined using CNC mills???
    Feb 2009
    UK
    The half hole you see is actually one of two halves that were sparked together as a complete hole so yes you can. The electrode is HDHC copper and as previously stated you can machine it on a cnc mill...you'd need a 3D CAM package though.
    1. Running stepper motor wire with router wire?
      By basskitcase in forum DIY CNC Router Table Machines
      Last Post: 02-19-2010, 11:18 AM
    2. Wire EDM - Wire Type and Size
      By greenchair in forum General Metal Working Machines
      Last Post: 06-17-2009, 02:44 PM
    3. I have 6 wire motors can I use a 4 wire driver
      By Musick7 in forum Stepper Motors and Drives
      Last Post: 05-05-2009, 11:39 PM
    4. power supply size? for multi wire (total 250 inches of wire)
      By DanOSB in forum CNC Wire Foam Cutter Machines
      Last Post: 03-02-2009, 05:34 PM
    5. How to wire an 8 wire stepper motor
      By technosteve in forum DIY CNC Router Table Machines
      Last Post: 01-16-2009, 06:01 PM
