http://www.hobbycnc.com/products/hob...oard-packages/
There is a FULL kit. At the bottom select 4 axis and 4 305Oz steppers and your good to go (even if you don't use 4 axis's now it will leave your options open). you will have to buy a transformer from the link provided, as well as a case separately. I purchased the kit and it worked wonderful, along with GREAT email tech support and a forum full of help.
Above is the video of the 4axis kit and board using mach.
You have to solder the board together, and assembly is required. good thing the directions are REALLY good.
That got me going from nothing to a fairly good understanding of the whole process. Without that kit i would be 100% lost haha.
