Originally Posted by
tessen
Hi to everyone!
I have a problem and i donīt know how to solve, i hope someone can help me, the problem is as follows:
I installed a THC but can not get the system work, seems to work, but the z axis does not respond to the instructions from THC, I set a reference voltage in THC, and the THC should up or down the torch according to that fixed voltage, but doesnīt do, with THC off works well (the machine complies with the G-code), makes the piercing at 3mm from surface, then down to 1.5mm to cutting and when it ends, lift up to 4mm
but when the THC is on, it makes the piercing at 3mm from surface, down to 1mm to cutting, and after cutting lift up to 4mm, I leave a video, in video you can see the led up and down bright but z axis not response/move
