Results 1 to 2 of 2
Thread: Kaliburn Plasma Machine
    Registered Donie's Avatar
    Mar 2010
    Ireland
    Unhappy Kaliburn Plasma Machine
    Hello there, Newbie on the site.
    Have a quick question on a Kaliburn machine i use at work. The Machine has started to use consummables at a serious rate. Especially the Shield caps.
    There is a slag left inside the cap, and it blows the centre hole out completely. Thinking along the lines of contaminated air. I have checked the compressor and the air is fine,no oil or water present. Could moisture be getting in from the Oxygen Bottles?? I have not changed height pierce settings and the torch has a THC
    Any ideas welcome, I will try to get some pics up tomorrow
    Cheers
    Donie
    Apr 2009
    Hard to say without knowing which model you have.
    Check to see if your pilot arc relay, if it has one, is welded shut.
    Sounds like some of the cuting current is staying in the PA circuit after transfer.
    Just a guess,
    Alan Bradford
    www.plasmatechnologies.com
  1. Newbie- Want to buy the RIGHT cnc plasma machine
    By boros40 in forum General Waterjet
    Last Post: 01-24-2009, 10:18 AM
  2. Need Help!- WANT TO BY CNC PLASMA MACHINE
    By ArielPR in forum Want To Buy...Need help!
    Last Post: 07-14-2008, 10:37 AM
  3. New Machine Build- 6' X 12' Plasma machine
    By 47MLB in forum Plasma, EDM and other similar machine Project Log
    Last Post: 06-08-2008, 02:12 PM
  4. Plasma Machine
    By Hellbringer in forum General Waterjet
    Last Post: 01-07-2008, 05:53 PM
  5. plasma machine
    By CARLES in forum Mach Software (ArtSoft software)
    Last Post: 03-14-2007, 04:45 PM
