Results 1 to 3 of 3
Thread: Toroidal Selection
    *Registered User*
    May 2009
    Toroidal Selection
    I try to select a toroidal power supply for the following and any suggestions would be much appreciated. Please suggest couple choices in case one is not available.
    The Gecko G540 digital 4 axis motor control + 4 Stepper motors 381oz-in. I have attached here the motor spec and the G540 has 0-3.5A rated phase current, 18-50VDC.
    I don’t want to make my own toroidal because once I did I had a heck of a time to get the right parts and at the end I don’t think the savings was that great (but the experience was). So the available choices of toroidal are: 48VDC/7.5A, 38VDC/15A, 48VDC/13A and 50VDC/10A.
    I would prefer the 48V/7.5A but I think the Amps are too low so the next choice will be either the 48V/13A or the 50V/10A (I think)
    Also I’m not familiar with the “Digital” G540. Does it need any special wiring and would it work with Mach3? What the digital means?
    Feb 2007
    canada
    The 48 volt 7.5 amp (almost 400 watts) would be plenty. Stepper drives draw a lot less than they supply to the motor.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    *Registered User*
    May 2009
    Thank you Larken for the infor but I found a 36V/10A power supply in my shop and I will use that one to get going. If not sufficient then I will get the 48V
  1. Need Help!- Need to bypass Random selection/shortest path tool selection method
    By Tizbass in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-12-2012, 08:38 PM
  2. toroidal Transformers
    By wjfiles in forum Hobbycnc (Products)
    Last Post: 08-30-2006, 12:01 PM
  3. Help with Toroidal Transformer
    By bill south in forum General Electronics Discussion
    Last Post: 08-02-2005, 03:40 PM
  4. Toroidal
    By Cyclone in forum Stepper Motors and Drives
    Last Post: 04-18-2005, 02:16 PM
  5. Toroidal
    By Cyclone in forum General Electronics Discussion
    Last Post: 04-13-2005, 09:18 PM
