Results 1 to 3 of 3
Thread: Proximity vs Limit
    *Registered User*
    May 2009
    Proximity vs Limit
    Looking at a youtube video the guy was using proximity sensors instead of limit switches on his CNC
    What is the difference between the two and is one better than the other?
    Feb 2009
    Depends on what they are used for. Proximity has no mechanical parts to wear out, higher cycle rate, and usually smaller. Limit switches are better for overtravel and other stuff you don't want to risk with a prox not picking up. Limit usually can handle more current and multiple voltages.
    One is not better than the other, just depends on use.
    *Registered User*
    May 2009
    Thank you, I guess I will stick with the limit switches for my new CNC
  1. PROXIMITY HELP
    By GANESHAN in forum General Electronics Discussion
    Last Post: 12-29-2011, 12:01 PM
  2. Proximity or mechanical limit switches?
    By gearsoup in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 06:16 AM
  3. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging,Extrusion...
    Last Post: 07-11-2009, 11:38 AM
  4. New Machine Build- limit switches -proximity sensor vs optical
    By circlecn in forum Benchtop Machines
    Last Post: 09-11-2008, 12:10 PM
  5. PROXIMITY SWITCHES
    By CHANDRU in forum General Electronics Discussion
    Last Post: 12-12-2007, 08:33 AM
