Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: I got this idea for a CNC machine controller.
    May 2010
    Lightbulb I got this idea for a CNC machine controller.
    I was thinking about this lately:
    How hard would it be to build a CNC machine controller that has a micro SD card slot, so when I want to debug the G Code and make a test part, I control the CNC machine with a computer directly, but when everything is already worked out, I save a G code file on the SD card and the controller reads the code off the SD card and no computer is needed.
    I tried building this kind of controller, but I really could not find any information on how to build a device that is visible to a PC as an external memory, in the file explorer.
    I envision this controller to be like a digital camera, so it can work when it is attached to the machine and on its own, except instead of saving information to the SD card, it will read the G code off the SD card.
    Not something I could build using PIC18 microcontrollers and my limited knowledge of USB.
    You are welcome to build your own devices that work on this principle if you like my idea.
    If it works out, send me a circuit, please. If you commercially succeed at building a controller like this, please send me one.
    Mar 2003
    Shelby Twp, MI....USA
    Feb 2012
    England
    What benefits would this idea have over the computer?
    May 2010
    Quote Originally Posted by HorridHenry View Post
    Well. The benefits are that computer is really an overkill to run a CNC machine.
    Too much processing power.
    Plus you have a hard drive, a communication line. More things can go wrong in process of manufacturing.
    Feb 2012
    England
    Well it can store a lot more information than a mem card ie you'd have to have a bunch of mem cards and swopping and changing.
    And how would you select a certain file to machine from the card? and mem cards are not that reliable.
    May 2010
    Awesome project. I wish that I could be the one to beta test it.
    Feb 2012
    England
    Awesome project.
    It will never catch on,people like to take control of their machines rather than slip a card in and away yer go ie its the joy of routing a piece of work and the end result gets us with a big smile.
    May 2010
    In a factory it may if the production does not require extreme precision.
    If no compensation for cutter wear is necessary.
    Feb 2009
    It takes a huge amount of processing power to contour at high speed. All the big players went to 64 bit long before pc's ever did.
    Feb 2012
    England
    You will still have to plug the card into a computer to transfer the data over for the job piece,,,,so rather defeats the object doesn't it.
    Mar 2003
    Quote Originally Posted by podolskiy View Post
    The developer dropped the ball on it. I believe that anyone who wanted could purchase one.
    They are used in the Shark routers that Rockler sells in standalone mode with SD cards, I believe.
    And mach3 has a plugin to use it with the PC, but the plugin was never fully completed due to an apparent lack of help from the developer of the NcPOD. If the developer would have worked to get a fully functioning Mach3 plugin, they would have sold thousands of them. Instead, everyone who purchased them eventually moved on to different hardware.
    May 2010
    Quote Originally Posted by underthetire View Post
    How did big players move to 64bit if PCs didn't?
    What were they using?
  • Page 1 of 2 12 LastLast
    1. CNC faceting and engraving bit machine idea.
      By twistedfuse in forum DIY CNC Router Table Machines
      Last Post: 05-03-2009, 04:23 AM
    2. Low cost idea for machine ways. Thoughts?
      By jstuedle in forum DIY CNC Router Table Machines
      Last Post: 06-28-2006, 08:05 PM
    3. I'm still new to this and so is this machine idea?
      By toad32 in forum DIY CNC Router Table Machines
      Last Post: 12-24-2004, 02:41 AM
    4. Idea for machine
      By SPEEDRE in forum 80/20, TSLOTS and other Aluminum Framing Systems
      Last Post: 11-13-2004, 01:01 PM
