Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Motion Detector as a limit switch
    Feb 2012
    England
    Instead of using a Micro switch I'm thinking of employing this circuit into the CNC.
    Anyone see a problem using an Infared motion detection rather than a mechanical one?
    Attached Thumbnails Attached Thumbnails Motion Detector as a limit switch-ir-motion-detector-circuit.jpg
    hgk
    hgk is offline
    Nov 2008
    led question
    Just curious, why does it need a transmitter instead of just being a switched on ir led?
    Regards -George
    Feb 2012
    England
    Its a beam breaker IR ie any solid intrusion between the beam triggers the limit line on the bob.
    Oct 2006
    UK
    Quite a few people do use them but you need to guard against swarf and coolant. I think the most reliable way is to have a tag or arm going into a slot in a body that's holding the switch.
    You could also try proximity switches.
    Steve
    Mar 2007
    The circuit you found is for a motion detector, like for turning on a light in your yard! Fine if you want to know if someone gets near your machine, but will never be a limit switch. Micro switchs are so cheap & simple I wonder why you feel the need to use something more complex.
    Jul 2009
    Quote Originally Posted by HorridHenry View Post
    Henry,
    Check this out:
    LMDC Catalogue: Servo Components
    Scroll down approximately 2/3
    OPTO LIMIT SWITCHES
    Ron
    Aug 2008
    Pakistan
    you can forget about using the receiver circuit
    When the transmitter frequency would be close to 40kHz then use a off-the-shelf IR remote receiver IC (found every where in all remote controlled devices).
    It is a three terminal device with + - and out terminals
    when receiver window faces you then left most pin is +5V mid pin is Gnd and right most pin is Data out which will be +5 when no IR beam and 0V when the beam is detected.
    so easy to use.
    and so cheap in price.
    best of luck
    Feb 2012
    England
    The circuit diagram says its that but its an Infared beam sent to a phototransistor and when an object breaks the beam it triggers whatever is connected to pin 7 ie a relay,ect
    We have all seen them in art gallerys,banks,museums,it doesn't detect motion as such but merely an obstruction in its straight path.
    Feb 2012
    England
    so easy to use.
    Exaclty,all parts can be got from scrap electronic consumer products.
    Dec 2003
    Is there any reason then you are not using an ordinary infra red slot detector?
    Mar 2007
    Not just the diagram says it's that, but the description says so too, read it again. The diagram is deceiving. It works like radar not a beam breaker. Like Al said, "infra red slot detector" they are beam breakers & cost the same as a micro switch. Or you can get some out of old printers, they used them for paper and/or jam detectors. Lots of info at OPTEK Technology: Optoelectronic and Lighting Solutions
    Mar 2012
    Proximity sensor would be a better option if you are dead set against micro switches. Although it would be easy to acquire and infrared set from a garage door, or as above from a printer.
  • Page 1 of 2 12 LastLast
    1. Is it possible to use the home switch as the limit switch as well?
      By Darc in forum Mach Software (ArtSoft software)
      Last Post: 11-02-2012, 01:25 PM
    2. Limit switch replacement with proximity switch?
      By Normsthename in forum Bending, Forging,Extrusion...
      Last Post: 07-11-2009, 11:38 AM
    3. limit switch and home switch setup
      By Runner4404spd in forum General Electronics Discussion
      Last Post: 12-15-2005, 08:58 AM
    4. Limit Switch / Home Switch in Software
      By Sanghera in forum General Electronics Discussion
      Last Post: 11-01-2004, 06:58 PM
