Results 1 to 4 of 4
Thread: what vinyl do I need to use
    Site Owner CNCadmin's Avatar
    Mar 2003
    I'm trying to cut out letters they range from 1/2 to 1", I'm using high performance vinyl it's 2mils thick and I'm having a hard time weeding it, should I be using something thicker?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Registered Big-tex's Avatar
    Jul 2009
    What purpose list your set up what equipment are you using bit etc more info you give better chance I will have to help you....
    Sep 2007
    vinyl letters
    As a signmaker myself, any letters that small are hard to weed. BUT, make sure your plotter is set to cut slow, and deep if it's hard to weed. High performance is the easiest vinyl to weed, I would suggest staying with that.
    Registered Kipper's Avatar
    Jul 2006
    England
    Quote Originally Posted by CNCadmin View Post
    For 2mils thick I'd use a router....unless you mean .2? I have some stickers I cut in reflective material that thick and I cut at 400 mmpm and 70 whatevers on the force setting.....must find out what the force is measured in!
    Keith
  1. Vinyl paint masks (what type of vinyl?)
    By SteveC68 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2010, 04:02 PM
  2. Vinyl Cutter
    By Ursine in forum Joes CNC Model 2006
    Last Post: 10-29-2009, 10:41 AM
  3. vinyl
    By tnc in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-19-2006, 11:33 AM
  4. Hot Melt Vinyl
    By diemaker in forum Moldmaking
    Last Post: 09-22-2006, 05:49 AM
  5. First vinyl cut with router
    By wedge in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 03-29-2006, 01:51 PM
