Results 1 to 3 of 3
Thread: 3D print out
    Oct 2010
    3D print out
    Using ArtCam 9.*** How can i put out a 3D view that I can e-mail to a customer for review? Also I need to get rid of the waste cut material in the view.
    Registered Pplug's Avatar
    Jan 2007
    Quote Originally Posted by gene8522
    I don't have the program in front of me at the moment so some of the names of the menus might be wrong but... To get rid of the waste material move the z zero point of your workpiece to the bottom of your board. Then under the 3d view window click on the button on the top of the window that gives you the options for what is displayed in the window. Unselect "material" and the waste material will not show. You can't do this with a tool path preview though. To email a pict select the save option from the 3d view menu on the menu bar from the top of the window. Sometimes I have taken a screen shot and cropped it in Paint.
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
    Oct 2010
    Quote Originally Posted by Pplug View Post
    Thanks for the come back. I have tried to do a 3D view but all I get is A 2D screen shot. I'll try to do a full screen shot of the 3D window, that should work.
    "To get rid of the waste material move the z zero point of your workpiece to the bottom of your board." I'll look at moving the 'Z Zero' also.
    I've been trying to get a web site up and running, but I don't think my signs will be as impressive as yours are..............
    Gene
  1. how to 3d print?
    By lasernewb in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-28-2011, 04:37 PM
  2. How to print ion a 3d surface
    By whiteriver in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-20-2010, 04:39 PM
  3. cant print?
    By erase42 in forum BobCad-Cam
    Last Post: 11-30-2009, 09:05 AM
  4. Print Variabledata
    By cncboy1 in forum Okuma
    Last Post: 11-23-2009, 05:46 PM
  5. Need Help!- Is there a way to have BC print out a Blue Print of a drawling?
    By Stampede in forum BobCad-Cam
    Last Post: 01-05-2009, 08:36 AM
