Old 02-22-2010, 12:14 PM
almo0797 is on a distinguished road
Drilling Of End Plates
Can anyone out there help! We manufacture a lot of parts out of plate Aluminium which are basically profilled drilled and pocketed all in 1 hit. A lot of these plates have tapped holes in the sides which at present are added manually. This means the plates are marked out or drilled with a jig, but it can take as long to do this as it does to machine all the other features. We cannot use angled drilled heads due to lack of space in the carousel and these holes can be in all the sides. Does anyone else have this problem?
I would like to use something like an old horizontal miller with a large bed to support the plates easily whilst drilling. On some of the larger plates (2M X 2M) we use a radial arm drill which is not ideal.
Need A Quote- 303 SS Plates / slotted zcases Employment Opportunity 6 10-13-2009 02:01 PM
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
316 plates waldo2413 Employment Opportunity 9 09-24-2008 07:38 AM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
RFQ- For some aluminum plates. KSI Employment Opportunity 2 11-06-2004 12:21 AM
