Old 04-18-2005, 07:16 AM
kong is on a distinguished road
Drilling/boring aluminium in the lathe
Hiya guys, I am in need of a faster way to create a large bore in aluminium. I need to make a hole 53mm diameter, 40mm (ish) deep in 6082 ali. I usualy bore it in the lathe after drilling a 20mm diameter clearance hole.
Unfortunately I am having so much trouble boring it afterwards, what with the nasty long chips inside that deep bore, I need an alternative.
I don't know a lot about drills, and have come across u-drills. Will these be a useful tool to use, or is there a better drill for my application? Any help appreciated here, thanks Jason.
Oh yeah, I need to keep the hole flat-bottomed too!
Old 04-18-2005, 07:36 AM
DAB_Design is on a distinguished road
Are you wanting to drill straight to finish? Or is a 2nd boring operation going to be used?
Old 04-18-2005, 07:39 AM
There will need to be a boring op afterwards.
Old 04-18-2005, 07:43 AM
Have you looked into a Metcut (brand) style indexable drill? We use these alot in all types of material. In aluminum, speeds and feeds can be quite high if the setup is rigid enough.
We also use one of their counter-bores to go straight to finish on .785 +/- .005 holes. Repeatability is excellent. We get about 90 holes before rotating inserts (6-4 tit.).
Old 04-18-2005, 08:03 AM
Thanks, these look like the u-drills I am on about. U-drill is probably the trademark name from sandvik that make them. They look the same.
So I take it these drills will drill without a pilot hole, or at least without a large pilot hole? At the moment, using standard drills, I work my way up the sizes, which is obviously time consuming.
Old 04-18-2005, 09:26 AM
No pilot needed. Make sure you don't use one too close to your finish dimensions. They do have a problem with going big if the feeds/speeds aren't just right. That's why we don't use them for finish (the drills not c-bores). However, if you need to drill close to your finish dimension, a pilot hole wouldn't hurt.
The biggest one I've used is approx. 2.3", on stainless. It did already have a hole in the center from a previous operation(apoprox. .68"). Pretty cool to watch. If you drill through, they push out a nice little disc great for frisbee.
Old 04-19-2005, 09:14 AM
Thanks Dab, I just bought a couple on ebay. Expensive, but hopefully worth it
Old 06-08-2010, 10:44 PM
raylht is on a distinguished road
need help for drilling dia 18mm depth 190mm alu on cnc lathe
Hi
any bros can help me to solve how to drill dia 18mm depth 190mm using drill bit? i ve tried using cnc lathe with long series drill bit, but hole taper at the extreme end. thks
Old 06-09-2010, 08:45 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
You need to break that chip- drill a hole off centre just inside your final diameter, that way long chips can't form when you bore it, after you've done the centre 20mm hole stick an end mill in (a drill would deflect) and mill a hole connecting that centre 20mm hole with just inside the outside diameter. No stringy chips
[edit]Do two or three if you want to be sure[/edit]
I love deadlines- I like the whooshing sound they make as they fly by.
Manual lathe CNC conversion kong General Metal Working Machines 10 08-20-2005 03:56 PM
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 02:07 AM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 04:20 PM
Just got a taig lathe. anoel Mini Lathe 2 01-18-2005 04:29 AM
non-circular lathe turning Help! oldguy General Metal Working Machines 2 04-06-2004 11:55 AM
