Old 02-17-2010, 11:04 AM
racecraft is on a distinguished road
Knurling 4130 Tube
I am trying to diamond knurl Military Grade 4130 thin wall tubing.
The Sizes are: 1.250" x .058" wall thickness
1.500" x .058" wall thickness
I have tried using a dual wheel bump knurling tool with plenty of Hangsterfer's cutting oil. My results are not working.
The material is so tough that the force you must put on the piece of tube in order to "bite" into the material makes the tubing flex off of the live center. I also end up with about a quadruple knurl.
Any help here? Any suggestions on tooling that would work better for this?
Thanks, Racecraft
Old 02-17-2010, 12:46 PM
newc is on a distinguished road
Try cocking your knurl rollers so they are more or less cutting on the front edge, rather than trying to shove the entire width into the piece. Then feed back and forth to get the width you need. Follow up with a little wire brushing to get rid of flaking, and you will end up with micrometer grade knurl.
Old 02-17-2010, 01:11 PM
sambo67 is on a distinguished road
you should try a c-clamp style knurling tool
Old 02-17-2010, 01:56 PM
CNC_Simon is on a distinguished road
You could try putting a filler piece in the tube to stop it deforming while you knurl it.
Old 02-17-2010, 02:22 PM
msomerville is on a distinguished road
I agree with CNC simon with a .058 wall that piece is going to push away on you all day long.
I will try all of these ideas. They all sound great.
How bout a good estimate on speed and feed for this operation? The knurls are 3/4" diameter and are HSS.
Any suggestions?
Thanks!
Old 02-17-2010, 02:45 PM
610 RPM
0.006 ipr infeed to depth (probably about 0.035)
0.012-0.015 feed towards chuck - don't dwell
You can repeat a time or two if you need to, in order to raise the knurl to a good height, but don't go over it too many times, it will start to tear.
Again, use the knurl rollers more as cutting tools than forming tools.
4130 should knurl up real nice.
Regards,
Newc
Old 02-17-2010, 03:03 PM
newc,
I think im misunderstanding the correct formula on what knurling wheels to use.
What TPI knurls should i be using for 1.250" material and for 1.500" material.
The problem i think i am also running into is that i can not turn the material to a specified diameter before i knurl it. So i have to try and get a knurl that has a TPI that will get me "close enough".
Just not sure how to calculate to get that.
Hope to hear from you soon.
Thanks, racecraft
Old 02-17-2010, 03:25 PM
racecraft:
Don't worry about it. There are formulas for all that crap, but just use what you have lying around. Turning to a precise diameter first is not necessary, just push the knurls in until you get a good height. They'll track OK, trust me. Again, turn the knurl holder so just the edges of the rollers are hitting the stock - doing more of a cutting action than a "knurling" action. CNC Simon has a good idea of putting in a plug to keep the tubing from collapsing, especially where you chuck it.
Regards,
Newc
Old 02-17-2010, 03:40 PM
sounds good, i will try this first thing tmw, and post my results.
thanks for the help guys.
Newbie- Tube cutting; tin slots and tube ends marineboy CNC Plasma and Waterjet Machines 0 10-13-2009 04:03 PM
4130 chromo mordantly Welding, Brazing, Soldering, Sealing 12 12-27-2008 11:35 PM
Need Help!- Milling 4130 Steel JWB_Machining General Metalwork Discussion 3 11-06-2008 11:04 AM
Filler Rod for 4130? Chris64 Welding, Brazing, Soldering, Sealing 7 09-30-2007 12:01 AM
4130 Steel FAMOUSX1 General Material Machining Solutions 8 10-12-2006 11:16 AM
