Hi guys , I am thread milling 15-5 ph stainless steel .Can anyone give me a recommended sfm and fpt for a solid carbide single point six flute 60 deg. form tool. I am getting a good finish with what I have but taking way too long. |
| Sambo Try 175-225 SFM with .0025 chip load as a starting point.
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| For me, it depends entirely on the number of posts/holes to be threaded, the time difference expected, and the cost of the tool and/or workpiece. If it will save 10% on time but eat up that savings in tooling or workpieces scrapped, it obviously isn't worth pushing it. I would look at the time/money saved using the above numbers to see if it is worth your while to change the settings on something that works already. It may be more worth your while to look at cost savings in another operation. Hope this helps, Fegenbush |
| thanks shotout , your recommended increase helped a little , still able to hold same finish . boss is still riding me to make better production rate for my operator but i guess what it is , is what it is. thanks alot |
![]() Cheers
| Single point threadmilling can be seriously time consuming. Shotout hit the f/s, thats right where I would be. Tap it? or Spring for a pitch specific thread mill, once around and done, instead of around and around and around and around and around and around and around and around and around and around. |
Experience with 316 SS 1/4 NPT Two passes with 6 flute solid carbide in a drilled and taper reamed hole. Tooling cost up front is higher but with high volume your cost will decrease per hole. Insert thread millers work too and are more versatile as they can be used for different pitch threads. Shop around and best of luck making any boss happy no matter what nationality.
__________________ If it is true a person learns from their mistakes then I must be the smartest man alive. |
| Thread Milling | Don Clement | Tormach PCNC | 23 | 08-01-2011 06:48 PM |
| thread milling | turbothis | Dolphin CADCAM | 5 | 11-11-2009 10:58 PM |
| Newbie- Thread milling | shake n bake | Mazak, Mitsubishi, Mazatrol | 2 | 01-09-2009 04:04 AM |
| 3M and thread milling? | teamjnz | Fanuc | 4 | 11-03-2008 07:09 PM |
| Need Help!- Thread Milling on v22 | PinMan | BobCad-Cam | 9 | 07-28-2008 06:42 AM |
