This may sound like beginners class but I am trying to turn or mill an internal shape to hold an er16 collet. I know it's just an 8 degree taper from start to finish but I don't know how and can't find a taper canned cycle. |
| Here is a short program I wrote to cut internal ER tapers. It is written for Turbo CNC, so you might need to change the syntax a little for Machs commands. It will cut any ER taper ( Actually it will cut any taper if you change the angle in line N200)... It assumes the stock face is at Z0, and is written for a diameter mode, metric lathe, and has been tested cutting an ER-32 internal taper. ;Cutting ER Tapers N100 Ask #1 ; Which ER size? N110 Ask #2 ; Starting bore size? N120 Ask #6 ; Depth of roughing cuts? N130 Ask #7 ; Roughing Feedrate? N140 Ask #12; Depth of finishing cuts? N145 Ask #8 ; Finishing feedrate? N150 Ask #10; Finishing allowance? N160 Ask #11; Number of Spring cuts? ; N200 #4 = 8 ; Taper angle of ER 32 Collet N210 #5 = [#2 + #6] ; Initial X target ; N500 G0 Z1 X[#5+1] ;Start outside cut to take out backlash N510 M00 ; Clear chips N520 #9 = [-(((#5 - #2) /2 ) / tan (#4))] ;Calculate Z target. N530 SAY #9 ; Z target N535 G01 Z0 X[#5] F[#7] ; Feed onto start point N540 G01 Z[#9] X [#2] ; Cut Taper N560 G01 X[#2-1] ; Clear Part N570 G00 Z1 ; Retract N580 #5 = [#5 + #6]; Increment DOC N590 IF #5 GE [#1 - #10] M97 O1000 ; Check if finished roughing N600 M97 O500 ; N1000 M00;Finishing - Set up tools and speeds. N1010 #5 = [ #1 - #10]; Set to take a pass at the Finish allowance N1015 G0 Z1 X[#5+1] ;Start outside cut to take out backlash N1020 #9 = [-(((#5 - #2) /2 ) / tan (#4))] ;Calculate Z target. N1030 SAY #9 ; Z target N1035 G01 Z0 X[#5] F[#7] ; Feed onto start point N1040 G01 Z[#9] X [#2] ; Cut Taper N1050 G01 X[#2-1] ; Clear Part N1060 G00 Z1 ; Retract N1070 #5 = [#5 + #12]; Increment DOC N1080 IF #5 GE [#1] M97 O1500; Check if finished cutting N1090 M97 O1020 ; N1500 M00; Spring Cuts N1510 #5 = #1 N1515 SAY #11 ; Remaining spring cuts N1520 G0 Z1 X[#5+1] ;Start outside cut to take out backlash N1530 #9 = [(((#5 - #2) /2 ) / tan (#4))] ;Calculate Z target. N1540 G01 Z0 X[#5] F[#7] ; Feed onto start point N1550 G01 Z[#9] X [#2] ; Cut Taper N1560 G01 X[#2-1] ; Clear Part N1570 G00 Z1 ; Retract N1580 #11 =[ #11-1]; Start counting down. N1590 If #11 LE 0 M97 O2000 N1600 M97 O1515 ; N2000 M02 ; End Program
__________________ Regards, Mark www.wrathall.com |
| Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread | bdyenter | General Metalwork Discussion | 2 | 09-16-2009 08:10 AM |
| Need Help!- ER16 Collets **INCH** | cnciam | Benchtop Machines | 5 | 12-07-2008 12:03 PM |
| ER16 collets | Astroguy | Benchtop Machines | 5 | 05-26-2007 02:05 PM |
| ER16 8* taper = OK to use for QTC (ATC)? | nicad | General Metal Working Machines | 6 | 08-24-2005 10:05 AM |
| looking for ER16 collet specs | nicad | Benchtop Machines | 1 | 08-15-2005 08:20 AM |
