Old 02-02-2010, 05:02 PM
AelfgarFaulkes is on a distinguished road
How to determine machine size?
I am new to machine shop work. I am interested in it to satisfy some artistic ambition that I have. I currently do not own a lathe and I want to learn more about them before I make the plunge. Background: I want to build a device that resembles a large steam guage from a railroad engine. I believe that the outside of the guage can be machined from 6061 Al tube and is basicly a turning operation. This guage will have an approximate outside diameter of 7.5 inches. it will be approximately 4 inches deep. The only external machining would be to provide a good finish on the piece. This is the biggest part that I will have occasion to build for the next several projects (if ever). Questions: What size of lathe would I need to be able to do this successfully? Do any readers have other information or suggestions that a newby might need to know on this particular subject? I will appreciate any help that you can throw my way.
Old 02-02-2010, 06:04 PM
bolton78 is on a distinguished road
it depends,on allsorts of factors.you want a manual lathe or cnc? new or used?
7.5" isnt a that big so i would suguest a hobby lathe,best bet it google,then you can make your own mind up.hope that helps somewhat
SUB CONTRACT MACHINING,CNC PROGRAMMER USING POWEMILL,MASTERCAM,MECHNICIAL DESIGN ENGINEER USING AUTOCAD,INVENTOR,POWERSHAPE www.cadtechuk.co.uk
What's your machine size? Karlf DIY-CNC Router Table Machines 18 08-04-2009 09:40 PM
MACHINE SIZE LYN BYRD Mach Software (ArtSoft software) 6 04-17-2008 12:42 PM
How to Determine Lathe Size bill south General Metal Working Machines 1 10-14-2006 09:54 AM
What size machine to build? CNCMP DIY-CNC Router Table Machines 6 01-04-2005 01:36 PM
how do i determine what size stepper motors to use? capitalv General Electronics Discussion 3 01-20-2004 02:22 PM
