Old 01-29-2010, 12:07 AM
Maxz is on a distinguished road
How to offset VMC
Dear all,
I would like to contour the profile shape like "8" (outside shape only). But my blank size is quite big. I have to rough the size of my workpiece.
- first time, I just lie the machine that I use tool diameter 25 mm (in fact, I use dia 5mm)
- second time, I use the real big tool diameter 20 mm. The result is the same.
The result is machine is alarm. I notice that I cannot lie the D tool's value bigger than workpiece's R.
Please anybody tell me how can I offset the (real) current cutting path at the machine, instead of offset it in the desktop. I would like to use only 1 program from rough to finish machining.
My control is Fanuc 18M,
I use I J with G41 (G2 and G3)
Thank you in advance.
Maxz
Old 01-31-2010, 12:56 AM
punchpressman is on a distinguished road
Maxz,
try this I run a 6M Fanuc .When using cutter comp. G41 ,G42 a total of 5 lines at least of G1,G2 or G3 with feed no rapids so machine can calculate the offset path. Also remember you cannot cut a radius with a D offset that is larger than the radius you want to cut. example ( if D31 is cutter radius of
.500 inches) program radius has to be .500 or larger.
Hope this helps
Punchpressman
Old 01-31-2010, 01:48 AM
guru is on a distinguished road
You can lie to the machine by program for largest dia. that will fit inside corner rad on work piece, when run finishing pass just put in negative cutter comp.
Radius Offset and Length Offset jim_stoll Dolphin CADCAM 13 10-14-2010 07:47 PM
FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! cjchands Fanuc 2 05-25-2009 11:22 AM
Need Help!- Offset Nat Wheatley BobCad-Cam 2 02-03-2009 01:49 PM
Second offset maximusek CNC Swiss Screw Machines 0 01-14-2008 01:08 PM
No offset CNCadmin LazyCam 4 08-13-2007 12:28 PM
