Old 01-26-2010, 09:08 AM
Micro Milling is on a distinguished road
Breathing safety around milled metal?
I was wondering if there is any hazards to breathing in milled brass or steal dust. I would assume that there is much fine dust being thrown around when milling, and sometimes I blow the surface of my table off to clear off the metal. I was wondering if the smaller dust, probably dust you can't see, will be hazardous to my lungs if I breath it in?
Anyone know anything about this area?
Old 01-26-2010, 09:47 AM
Delw is on a distinguished road
the smoke from Brass is Toxic( from what I was always told) when cutting it on a lathe dry.
I would Imagine milling it dry would give the same effect.
Old 01-26-2010, 10:04 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Some metals are really nasty to machine due to inhalation hazards. Beryllium is one such, I believe, and you have to assume depleted uranium would be too!
I have never heard this to be the case for steel and aluminum, but unless you're grinding, your chips should be bigger than dust anyway.
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
safety conscience, or safety paranoia? Marino MFG Safety Zone 2 04-03-2009 03:34 PM
First milled PCB Jason Marsha PCB milling 36 11-18-2008 08:49 PM
I need some slots milled in some 14 ga SS. Jeff Wohlt Employment Opportunity 2 10-31-2007 05:02 PM
RFQ Al plate/milled roninB4 Employment Opportunity 8 09-07-2006 01:23 PM
Breathing fumes... Tebis General Metalwork Discussion 3 09-06-2006 06:23 PM
