Old 01-24-2010, 10:18 PM
Brenck is on a distinguished road
Cool Engraving Aluminium Feed Rate And DOC?
Hi all,
I have 30 degree ''V'' kind engraving tools carbide made I would like to engrave aluminium, I have seen charts of feed rate for that but the max rpm was 15000rpm, but my spindle is a 26000rpm what is the feed rate I need to use with that much rpm? Im afraid that if I go to slow aluminium will stick to the tip due to the heat and i will break the tip of the tool. I never used this kind of tool
What about depth of cut how deep i go per pass?
Thank you,
Gustavo
Old 01-30-2010, 11:14 PM
aaron p's Avatar
aaron p is on a distinguished road
ive always engraved with a #0 center drill, and around .005" DOC, and 2,000-3500 rpm, solid carbide.
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Old 02-02-2010, 11:55 AM
kling8 is on a distinguished road
I run my spindle speed around 6000 rpm feedrate 40, depth around .001-.003 there is alot of room to play with speeds and feeds with these tools, just don't go to deep. and watch your finish
Old 02-02-2010, 12:39 PM
austin.mn is on a distinguished road
I have been using a ridged router running 16000 rpm. I use a 60 degree bit from precise bits, and have been able to run .03 deep regularly with flood cooling cutting 6061.
http://www.precisebits.com/products/...ounteredge.asp
I use the EM2D8-1250-60V with .250 bushing.
Old 02-02-2010, 12:54 PM
Thank you all for the replies. I used 40 ipm at 26000rpm and it worked pretty good d.o.c was 0.004 per pass
Tags
aluminium, engrave, engraving, feed rate, feedrate
Okuma mill feed rate jumps to rapid feed easyguy97 Okuma 6 12-20-2009 04:14 AM
Need Help!- Feed rate for 5/8-18 tap Eagle View General Metalwork Discussion 2 09-24-2008 09:25 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-21-2007 11:12 PM
C & Z Feed rate rfstar G-Code Programing 7 06-22-2005 12:38 AM
