Old 04-11-2005, 07:42 AM
Chris D's Avatar
Chris D is on a distinguished road
gear hobbing....
Hello group,
I want to play around with some gear hobbing. Nothing fancy, but would like to tinker with it.
I want to cut two spur gears that mesh together, one having 100 teeth @1.9894 dia. and the other having 20 teeth @ .3979 diameter. This will give me a ratio of 5:1 and a tooth pitch of .0625. When I draw this up in CAD, I notice that the teeth will bump into each other as they rotate through.
For the hob, I plan on turning it on a lathe with a custom ground threading tool to match the tooth form. The actual hobbing will probably be done on my mill as there is more room on that machine for fixturing the blanks etc.
I am pretty sure that the shape of the threading tool is not going to be the exact shape of the tooth form. I suspect that the hob is going to alter the tooth shape to "automatically" provide the tooth shape to provide the clearances so that the points of the teeth don't rub as they rotate together.
Does anyone have any experience with home shop hobbing that can provide some pointers?
I have plenty of machining experience, but and pretty stupid when it comes to gear machining (except for making the blanks).
TIA!
Chris
Old 04-11-2005, 07:19 PM
Mcgyver is on a distinguished road
Every time I think of making a gear hobbing machine the difficulties in making the hobs, not the machine, talks me out of it. The form on the hob looks more like an acme thread as I recall, but the difficult is cutting the relief. Picture cutting a very coarse thread with compound feed disconnected and moving in and out on a cam several times per rev to create relief behind the teeth.
Did you arrive at those dia's using gear formula? I think you've done it correctly, as both have the same dp, but the dia you get is the circular pitch, not the outside dia. Maybe that’s why it’s not laying out well.
There were some excellent articles a few years ago in making hobs in Model Engineers Workshop magazine. There was also a series on making a hobbing machine from castings, of bench top dimensions. Well worth tracking down some copies – most of the theory and practical aspects are covered
Old 04-12-2005, 06:57 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
You could buy a gear form cutter (like you would run in a horizantal mill) and slice it int 4-6 (or whatever) pieces and you will have a handfull of "pre-shaped" hobs that you can make a toolholder for.
On the other hand... I assume you must have a rotary table the you will be using the index between teeth? It would save you many,many,many hours of hobbing if you would stand your rotary up, fixture your blank on an arbour, and just cut the gears with the horizantal cutter in an arbour.
www.integratedmechanical.ca
Old 04-12-2005, 01:26 PM
I know just enough about this to help out a bit, but if there is an expert around jump right in.
the profile of a tooth of a gear cutter is not the profile for a hob and the hob doesn't require any indexing, only the relative rate of rotation between the hob and the blank. I think the profile of the hob, which is like an acme thread, is determined by the pressure angle.
The advantage of hobbing is you only need 1 cutter for any number of teeth (for a given dp) and you can cut bevel gears etc. It's also more accurate as the gear is generated as opposed to the form cutter which is an approximation (that’s why each only cuts a range of teeth). Without a huge amount work, I don't know how you could hob in the mill as the basic principal is two rotating shafts connected via a gear train, one with the hob, the other with the blank and slide mechanism to control the distance between in two planes (depth of cut and traverse the hob across the blank).
I agree with the recomendation of just cutting the conventional way though
Here's a link for a video claiming you can easily do it for $3 http://technicalvideorental.com/rental_15.html
If thats the case, I'm guilty of overestimating the rigores of getting set up to hob gears!
Old 05-13-2005, 04:11 PM
I learned some neat ways to make gears with cnc applicability - thought this crowd would find it interesting.
First of all, Peter Harrison's site gives a very good description of what I'll call faceted hobbing. Its not really hobbing but it is a very cool way to make your gears and cutters without requiring true hobs, a swiveling mill table etc. As this needs is a lot of back and forth stuff/index repetition it would be great with CNC. You double up the number of facets approximating the tooth form by offset y ½ and indexing to the ½ tooth. This holds real potential for us home shop guys – don’t forget expensive commercial form cutters are also only an approximation.
http://homepage.ntlworld.com/peter_h...ting/index.htm
For the Rolls Royce idea check out this photo John Stevenson’s site. True cnc hobbing. He’s encoding the spindle speed to control the blank speed. Absolutely brilliant! This idea does require a proper hobber. The table is turned by the pressure angle, and you can cut helix gears by subsequently setting the 4th axis over. DIY CNC helix and crown gears – that’s taking it to a new level imo
http://homepage.ntlworld.com/stevens...20indexer4.jpg
http://homepage.ntlworld.com/stevens...0indexer12.jpg
Old 09-08-2006, 08:48 PM
Ball Screwer is on a distinguished road
There are several books and web sites on alternative methods of gear generation.
Old 12-12-2006, 10:26 AM
handlewanker is on a distinguished road
Hi all, I know this is probably a bit late in the day now, but from my point of view anyone contemplating hobbing a gear using the knowledge that you don't have, is trying to use a sledgehammer to crack a wallnut.
Hobbing is a production process and no-one in their right mind would set up a machine just to cut one or two gears.
It is the simplest job to set up a horizontal mill with a gear tooth milling cutter and dividing head and get accurate results in a very short time, and all this with a bit of tuition and knowledge.
I have hand ground a flycutter to cut gears when the required gear cutter was not available.
The flycutter was checked on an optical projector against a 50:1 projection chart for form accuracy and worked well.
I wouldn't recommend this for some very sophisticated gear requirement but the job in hand was for a change wheel for a lathe and was still working years later.
For complexity I would rate it the same as for cutting threads in a lathe.
I've also cut spiral gears, the same way, for a right angle drive in a horizontal mill with a vertical head, and the dividing head geared to the table leadscrew, a bit more complicated.
On one other job I had to cut two small racks, about 4" long with teeth at 1/8" pitch.
This was done using a Bridgeport mill and the cutter was a flat end mill type cutter ground to the tooth form.
The pitching of the teeth was done by the leadscrew of the X axis, and cut by traversing the cutter across the rack blanks,held in the vice, with the Y axis.
I still have the cutter, after 30 years, as a souvenir in case anyone doubts me.
Ian.
Old 09-03-2008, 11:26 PM
el_tony33's Avatar
el_tony33 is on a distinguished road
Hey there people!
I´m designing a gear making machine for a school proyect, and I'm really interested in any information that you can provide me please, about gear manufacturing
I already know there is a lot of books about this, but in the web? do you have a good secret place? jajaja?
I´m really in love with gears, and I know some automation concepts, all that I need is the step by step of the process, or a table of speed feed rates, speed recomended for the hob, etc...
In abstract the technical data of the process...
I promise that I will reply the advance of the proyect, that is intended to manufacture plastic and aluminium gears, because is going to be a "table size" machine..
Ok... well,... thanks for reading!
Old 09-05-2008, 08:18 PM
Tony, Do you intend to make a true gear hobbing machine or a milling machine using gear form milling cutters?
I'm in the process of designing a commercial gear hobbing machine. This is much more complicated than a milling machine.
If it's a CNC machine you will need to think about a few things like;
1) a work spindle drive (C axis)
2) a hob spindle drive (A axis)
3) a longitudinal drive (Z axis)
4) a cross feed drive (X axis)
All the above must be able to move under simultaneous control to produce a crowned and/or helical gear. It is possible to hob a plain spur gear by positioning the X axis for depth of cut and using C, A and Z axis' to cut the gear.
In addition, the hob spindle must be tilted to the correct angle to allow for the hob lead angle and if required gear helix angle. This can be done manually or as an additional axis 5.) (B axis).
Also, to spread wear on the hob itself, another axis is employed as the hob shift which can also be manual or under CNC control 6) (Y axis). This is also used to employ more than one hob on a common arbor to cut more than one pitch gear on the same workpiece.
If a CNC machine, you will need some pretty fancy software to co-ordinate all these motions.
Good Luck!!
Dick Z
DZASTR
Old 09-06-2008, 11:56 AM
Tony, Add. to post #10 above.
If you intend to machine gears by the milling method rather than hobbing, a far less complicated machine will work. Straight spur gears are the easiest and a good starting point.
A milling machine with an accurate indexing device is all the machine needed. An accurate arbor to hold the gear form milling cutter and an accurate arbor to hold the gear being cut is all the durable tooling required. The reason for all the "accurate" in this paragraph is to avoid the compounding effects of any inaccuracies.
For expendable (cutting) tools you will need gear form milling cutters. These can range from high speed steel, coated high speed steel, coated powder-metal high speed steel, carbide through coated carbide form cutters. There are indexable insert type cutters available.
There are different cutters for every pitch of the gear and different cutters for the number of teeth within a given pitch.
The speeds and feeds for these are available from the cutter manufacturers. Different speeds for different cutting tool materials and more different speeds for materials being cut.
One source for these cutters is Ash. I will try to locate their web page.
Dick Z
DZASTR
  #11   Ban this user!
Old 09-08-2008, 12:08 AM
el_tony33's Avatar
Well, I'm still working on it!
Thanks RICHARD!! For the info!
And...oooh wow, it is going tobe more challenging that I've been thinking!! jaja
well thanks for the help, and about the inclination of the hob for cutting is something I don't contemplate from the beginning, thanks!
I have been thinking in that axis of movement but not for that purpose, it was for making the inclinated tooths.
I´m working on the interface for the computer-program-driver-motor, I got a really fancy motors jaja and drivers too, I´m using some VEXTA, 5 Volts, 1Amp, And the driver is a Centent CN0162, for each axis.
I´m trying to control it from a program, using a laptop via RS232, the only inputs that need the centent drive is the direction and step pulse.
Becaue some inconvenients of time I can't make this divers work, RICHARD, have you or any one use it before? I found the manual but is not really good about explainig, and have a very few images and squematics
Ok back to the machine, I´m contemplating 4 axis:
1.- Z axis: The one that carries the motor coupled to the hob
2.- A axis: Rotation of the Z axis respect to the horizontal
3.- Y axis: Movement to get near the "work disc" to the hob to make the calibrations depending of the size of the work disc
4.- B axis: Rotation of the coupling that carries the work disk, for the spin feeding of the material, having the angle of rotation in his centre
I don`t know if I get explained :O?
Well, The angle that RICHARD say and I mention before, the one of the gear hob, it can be compensed with the A axis I suppose?
The milling methos the inconveinence that I see on it is the number of milling tools that you need for make a game of diferent number of tooths an module :S... So I was thinking that, yes, is going to be hardy, but at the end is much more better and "special" machine, and thats the goal of the proyect, to help to the design of the new generations of ingennering in my school, because in my generation we take a lot of time looking for the right gear and that kind of things that end with your designing dreams... So if you want to use gears, let's use the TONY'S MACHINE jajaja.... :P
Well I'm still working on it!!
Is really late, but in another post I will put some drawings that I made...
welll thanks again RICHARD!!
  #12   Ban this user!
Old 09-08-2008, 12:57 PM
tony, Get some prices on gear hobs. I think you will find that you can buy many gear form milling cutters for the price of one hobbing cutter.
I believe your motors/drivers will be a bit "light" for this job. The smallest hobber I ever worked on made gears smaller than 1" (25mm) in diameter. The spindle motor has 4.3 Nm continuous torque.
Remember, the hob spindle (A-axis), the work spindle (C-axis) and the hob directional feed (C-axis) must be ACCURATELY synchronized or you will produce a corn cob rather than gear.
People who create this kind of software can spend years developing it. Spur gears are the least complicated. In it's simplest form it's 3-axis. Include crowning and it becomes 4-axis. Add helical gears to the mix and it becomes 5-axis, all must be synchronous.
The hob shift is a 6th axis but not necessarily synchronized with the other 5 axis.
If you add multiple hobs to the mix, the hob shift an be employed in the CNC program. Adding more than one gear pitch, gear helix angle or hob helix angle and the hob head swivel angle will have to be included in the CNC program as well.
I'm not trying to discourage you, but trying to inform you of someof the "complications" you may/will run into.
Good Luck!
Dick Z
DZASTR
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
NASA gear bearing by mister Vranish wolphje General Metalwork Discussion 1 07-28-2005 01:28 PM
gear pitch 2muchstuff Mechanical Calculations/Engineering Design 5 04-02-2005 08:04 AM
Adding a manual gear change call MILLMANM Post Processors for MC 5 01-04-2005 10:05 PM
Gear reduction DragnsBane Stepper Motors and Drives 3 11-11-2004 05:36 AM
