Old 01-22-2010, 10:17 AM
Hennessy is on a distinguished road
G74 What am I doing wrong??
I am running a lynx 200L lathe with a fanuc 21i-t control. I keep getting an invalid decimal point error. I don't know what I am missing, the manual isn't to clear and I don't get what the error code is saying.
(END MILL .5 DIA.)
(TOOL - 5 OFFSET - 5)
G0 T0505
G97 S2000 M03
M8
G0 G54 X0. Z.25
Z.1
G74 R0.1
G74 Z-.4586 Q.1 F.002
G0 Z.25
M9
G28 U0. W0. M05
T0500
M01
I am still new at programing a lathe so any help would be appreciated.
Hennessy
Old 01-22-2010, 10:26 AM
dcoupar's Avatar
Q doesn't accept a decimal point. Try this:
G74 Z-.4586 Q1000 F.002
Also, I don't know if you're aware of the Daewoo/Doosan forum on this site...
Old 01-22-2010, 10:58 AM
Ah I see... now I get why Parameter 5139 is 1000. So how do I call out a peck depth?
Ya I posted here because I needed a quick reply. I got thrown in to the fire today. We needed some tooling made for in house use and of course it needs to be done ASAP. So I had 2 choices surface them on the mill which would take 2.5 hours a part, or run them on the lathe at 10 min a part. I also figured this was more just my lack of knowledge on using a code (not machine specific). Thanks for the quick reply it would have taken me forever to figure that one out.
Hennessy
Old 01-22-2010, 12:27 PM
dcoupar's Avatar
Just put a Q value in the G74 block. Parameter 5139 will update. If you don't include a Q in your G74, it will peck by the current value of 5139. I always include the Q as I want to be sure what my peck amount will be.
Old 01-24-2010, 10:46 AM
cncsam is on a distinguished road
g74
You need to change Q.1 to Q1000
Your canned cycle works using trailing zero's and not decimal programming
hope this helps,
sam
10 IPM, am I doing something wrong? jupdyke Mechanical Calculations/Engineering Design 8 09-16-2009 10:26 AM
I sure I'm doing something wrong but what?? dberrouard Mach Software (ArtSoft software) 9 01-16-2009 05:35 AM
What's wrong here? CharlieM Kellyware CAM 3 10-31-2008 02:50 PM
When everything goes wrong. ImanCarrot General Metalwork Discussion 4 04-23-2006 09:42 PM
anyone know what i am doing wrong pauluk Digitizing and Laser Digitizing 14 02-16-2006 10:48 AM
