I would of posted this in the automotive forum but it looks like nobody responds in there and I need a quick response. I just want to clean up this intake manifold. I am not to sure on how to mount it to support the work piece. I just need to run a fly cutter over it to just get it straight. please help -garrett |
| There is no easy way to do this other than making a hold down base that attaches to the carb side. This base would be your center pivot point . You need three points to level the surface, your other two points could be some 3/8 bolts pushed thru the bolt holes on the opposite side (I am assuming is a V8 intake) that you would pinch down to your table with some hold downs, and use shims to get the desired level. |
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452 |
| I used a surface wet stone grinder not a mill, however this setup might work as well. you could make the spigots out of 5/8 bolts, cut off the heads and turn down on lathe to 3/8. you could leave point B static and adjust spigot screw on point A's to get level or place shims in point B to get forward and back level. use a one or two chain clamps, hold downs, even welding a plate (to be cut off after) to manifold will work to hold down at carb (steel shim) point. crude but effective hope it could help you. is a tough one I know! PS. if is not too warped some 150 grit emery cloth duct taped to a nice straight steel plate and 15 minutes of elbow grease would work also but thats no fun nor challenging. lol Last edited by Cyclone; 04-08-2005 at 12:56 PM. |
| Machining rubber | HuFlungDung | Machine Problems, Solutions , Wireless DNC, serial port | 10 | 05-01-2011 03:59 PM |
| High Performance Machining or HSM | Scott_bob | Polls | 56 | 04-27-2006 02:34 PM |
| Machining 2219-t4 aluminum | scottwally | General Metalwork Discussion | 2 | 06-18-2005 10:53 PM |
| Reintegrating machining in our company | beast | General Metalwork Discussion | 18 | 03-24-2005 07:51 AM |
| One Hit Machining | CRPDGAZ | Hard and High Speed Machining | 10 | 03-24-2004 01:52 AM |
