Old 01-14-2010, 04:12 PM
kvom is on a distinguished road
Boring / flycutting on CNC mill
Are flycutters commonly used with CNC mills?
For boring, I know you can machine a round pocket, but I doubt that the finish would be as good. Does it make sense to use a boring head on a CNC mill, at least for the final pass?
Old 01-14-2010, 09:39 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Sure, kvom, you could do all of the above, just depends.
In the case of a boring head versus interpolating the hole, I doubt if surface finish would be the deciding factor. Rather, it would be accuracy of the bore. The boring head will do a better job, but it will be a lot slower, and probably less automated unless you have a real expensive one. If you have to hold real tight tolerances for a bearing, you probably need a boring head. If 0.001" is good enough, interpolate.
RE the flycutter, you could use one, but a nice face mill will get the job done faster.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Just IN- Looking for CNC Boring mill jlauch Want To Buy...Need help! 0 11-06-2009 08:10 AM
inner boring solutions for mill? MechanoMan Benchtop Machines 2 03-25-2009 09:53 AM
Flycutting: New Insert tikka308 Benchtop Machines 10 07-02-2008 07:29 PM
Boring Tool as an end mill? SV in SD General Metal Working Machines 57 01-30-2008 08:50 AM
Mill Boring Simplified. dapoling General Metalwork Discussion 3 01-29-2008 05:39 PM
