Old 01-12-2010, 11:18 AM
basswakr is on a distinguished road
edgefinder
i am looking for an electronic edgefinder that will work any material
i cut wood & plastic
any ideas?
thx
mike
Old 01-12-2010, 12:13 PM
CNCRim's Avatar
Check MSC catalog, normally Electric edgefinder work with metal ...... 'cause it need ground to trip the light. But I think they also have electric edgefinder with a spring load and claim work with any material but it's expensive you are talking $200 plus.
Old 01-12-2010, 12:34 PM
i checked they said they didn't have one
any more ideas?
thx
mike
Old 01-12-2010, 04:31 PM
mactec54 is on a distinguished road
Hi basswakr
There is a laser that you can use I don't have the spec but they are in the home machinist magazine
Found it http://www.lasercenteredgefinder.com/
Mactec54
Old 01-12-2010, 05:46 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Those kind of lasers are just visual, and not so accurate as a regular edgefinder.
I'd go with a 3D probe. The actually require the motion to move the tip to register the edge, so will work with materials that don't conduct electricity.
I got one like the one in this thread:
http://www.machsupport.com/forum/ind...ic,5004.0.html
Haven't had a chance to play with it yet, but it was very well made for the price.
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 01-18-2010, 07:09 AM
sambo67 is on a distinguished road
What's the issue with a standard edge finder ? If used correctly it will get you real close. If you need it closer you can always sweep edge with an indicator. Takes more time but very accurate.
Old 01-18-2010, 09:01 AM
there is no issue with reg. edgefinder
the electronic will be much faster & easier.
i ordered the probe that bob suggested &
will let u know how it works .
thx for all your help guys
mike
electronic edgefinder basswakr CNC Machining Centers 0 01-12-2010 11:16 AM
Newbie- Electronic edgefinder Hack General Metalwork Discussion 4 11-22-2009 09:53 PM
Aligning workpart with edgefinder similar to Mach3 possible? germaza LinuxCNC (formerly EMC2) 2 10-16-2009 01:04 PM
edgefinder krymis Industrial Hobbies (Support forum) 2 01-02-2007 10:40 AM
