| this can be easily done using edm machine. if ur left with no option other than cnc milling milling machine, the component can be done using 4th axis arrangement. but the cutter leaves its traces at the ends. length of the spline should be more than the working length. |
| Splines while you can make them on a edm or 4th axis they will never be 100% right I forget the proper name of the machine a gear shop uses, I wanna say a hob. a broach is pretty much for intenal splines. they do have them for od work as well We used to do thousands of parts (lathe work) splines for aircraft shafts. I can still picture the machine my vendor had but cant remember the proper name. |
| Hi wilson248 You have a lot of answers, You could do this your self with a manual mill a fly cutter ground to the shape of the spline, a 4 axes/ indexer or rotary table to hold the work The hole is nothing special you could drill this part on a lathe thread Etc The method for production would be to use a gear Hobbing machine, this process is very fast for such a spline, they can of cause be roll formed as automotive axles use this process If you look close at the part you will see how it was done, you can even measure what the diameter of the cutter they used by the radius at the end of the spline
__________________ Mactec54 |
#10
| Delw is right. Splines are commercially cut with a spline hobber. Splines CAN be cut with the proper form tool on a mill with an indexer. The form is usually an involute spline. Sometimes a straight sided spline. Accurate splines have about the same degree of difficulty as accurate gears. Dick Z
__________________ DZASTR |
#11
| The fastest and most accurate way to make this would be a Hob. I would say Hob as well.
| Need A Quote- Need advice about wood product, manufactured in Canada | Litografa | Canadian Club House | 0 | 01-10-2010 09:26 AM |
| How to get your PCB design manufactured ? | Konstantin | General Electronics Discussion | 5 | 07-29-2006 09:08 PM |
| Pricing A Cnc Manufactured Picture Frame | TheNigerian | CNCzone Club House | 8 | 06-23-2006 10:59 AM |
