Old 12-21-2009, 11:32 PM
andenbrendrew is on a distinguished road
Advice Milling 400 series stainless
Milling 17-4 series stainless with a 6in milltech f-mill .100 depth of cut 384 rpm 15 to 30 inch a min. I am chipping inserts after every 3 passes. Book says run 700rpm at 70 in a min. I am removing 6 inches of material form the part. THis is getting costly. Any advice would be apreciated.
Thanks in advance.
By the way yes It is a massive part getting 3d mill work done to it. Anything to make this go faster would be apreciated.
Sorry 1ts 17-4 stainless in condition A for roughing.
Old 12-22-2009, 11:51 PM
SAw and read the other post about 17-4 I believe all my troubles are from the milling outside and inside radiuses burning up the insert. Other than that we can run it really well. I also noticed in the other post that you all recomend finishing at .001 - .0015 chip per flute with a .02 step over it would take a couple weeks to finish one side.
Need Help with Stainless 300 series bb_24_1 Machinist Feedback 4 10-21-2009 07:36 AM
Need Help!- advice on angle milling without vice on bp series 1 cnc ajitsingh Bridgeport and Hardinge Mills 3 10-31-2008 09:03 AM
Need Help!- 300 series stainless, .020 thick, 40-45RC gearsoup Want To Buy...Need help! 0 02-29-2008 09:37 AM
TM-1 and milling stainless CJH Haas Mills 13 07-29-2007 08:43 AM
Advice for 0-80 tapping in stainless steel js machine General Metalwork Discussion 6 06-12-2007 03:06 PM
