Old 12-15-2009, 09:12 AM
svarzaru is on a distinguished road
Alloy suggestion, more rigid then brass.
I am making a camera and I need to make a part as rigid as possible (no flex). The rest of the camera is made of 260 brass which is not rigid enough for this part. What suggestions would you have for a metal/alloy that is more rigid then C260 brass? Due to aesthetics, it would be great if the color of the metal was as close as possible to 260 brass but I'll take any suggestions.
Thank you.
Old 12-15-2009, 09:24 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Steel.
http://en.wikipedia.org/wiki/Young's_modulus
Brass and Bronze are about 17 MPSI. Steel is nearly double that at 29MPSI.
It is not hard to copper plate steel, if that helps the asthetics.
Beyond that things get exotic. Carbide is about twice as stiff as steel.
Regards,
Mark
www.wrathall.com
Old 12-15-2009, 09:52 PM
Mcgyver is on a distinguished road
to add to that, go with a free machining stainless steel.....not hard to make stainless and brass ascetically pleasing .
is it a reproduction or can you design in stiffness, ie boxes, girders etc. stiffness to weight with these fabrications will be much better than a solid bar
CNC Spindle Alloy ? Joe_CNC General Metalwork Discussion 2 03-23-2009 04:15 PM
Newbie- Weld Brass to Brass piratesover40 Welding, Brazing, Soldering, Sealing 3 03-03-2008 06:02 PM
C-300 alloy steel 5th-axis General Material Machining Solutions 0 02-20-2008 09:17 AM
alloy 46 lelajoie Machinist Feedback 1 08-13-2007 03:34 PM
Alloy wheels kong Parts for Radio Control Models 22 12-04-2005 05:19 PM
