Old 12-01-2009, 10:02 PM
Big-tex's Avatar
Big-tex is on a distinguished road
A-36 vs. 304 strenght
As I do not much about metals my expertise is in wood. I have build DIY CNC router using 3/4x3/4x1/8 hot rolled steel (I believe a-36) on which roll my no.2 V bearings. After some time I started develop wearing which makes me believe that it will be inconsistent thus accuracy of my machine will suffer. I do not have local source for cold rolled which I believe would be more suitable for that purpose. I can purchase same angle to replace it made in Angle 304 Stainless Steel, Annealed & Pickled.
Would that be a better choice with more strength and less wear?
Old 12-04-2009, 09:35 PM
laka is on a distinguished road
Here's some info on the properties of each:
http://www.fanagalo.co.za/tech/tech_grade_304.htm
and
http://en.wikipedia.org/wiki/A36_steel
I would suspect that running a hardened bearing on either of these materials would cause them to wear over time - probably even at the same rates. Maybe look at getting some linear rails to replace?
Need Help!- Material strenght question... croosh DIY-CNC Router Table Machines 3 02-19-2008 07:41 PM
Y and Z strenght - will this be stong enought? Goose80 DIY-CNC Router Table Machines 12 12-29-2006 05:58 PM
Strenght vs. MBG Mechanical Calculations/Engineering Design 3 07-09-2005 09:44 AM
